blown fuse #985988 02/17/10 11:25 PM
RadiOwATt1oo Offline OP
Greetings.
Recently I had issues with my T-100 the engine start missing while driving.
I founded that it was caused by a 15A fuse blown located on the fuse/relay block on the driver's side of the engine compartment, so i replaced it for a new one but and it was ok for a few days but suddenly it just blows, then i changed for another one so i could drive a few blocks until i had another fuse blown.
Upset i went to the mechanic and he told me that the blown fuse controls the EFI (Electronic Fuel Injection) and that it may be a short caused by the fuel injection wiring harness that could be deteriorated. I know they're expensive
Any thoughts?
1996 Toyota T-100 DLX
3.4L 4WD
Re: blown fuse [Re: RadiOwATt1oo] #985989 02/18/10 02:26 AM
kewlynx Offline
Harnesses can have the insulation wear thru and start grounding wires; basic electronic stuff.
Time for you to start chasing down the problem. I had an ENG fuse a few years back do the same thing. Fixed the wiring.
**ubi apis- ibi salus**
Re: blown fuse [Re: RadiOwATt1oo] #985990 02/18/10 04:55 AM
BamZipPow Offline
Yup...sometimes it's from someone doing work and having something rubbing up against the harness. Just take yer time tracing the wires and go inch by inch. <img src="/forums/images/graemlins/smile.gif" alt="" />
Re: blown fuse [Re: BamZipPow] #985991 03/17/10 06:08 PM
Thanks problem solved, now im thinking about getting a catallytic converter
Re: blown fuse [Re: RadiOwATt1oo] #985992 03/18/10 01:12 AM
kewlynx Offline
So what was the fix; wiring? If so, where? Good to know if this should be a spot to keep an eye on for folks.
Check RockAuto's prices for a cat.
PHP: 7.4.33 Page Time: 0.010s Queries: 15 (0.008s) Memory: 0.6092 MB (Peak: 0.6739 MB) Data Comp: Off Server Time: 2026-11-03 13:36:55 UTC
