New clutch and front drive shafts...what else to check? #986129 02/18/10 05:32 AM
shorepig Offline OP
I am going to have a new clutch put in my 92 V6 3.0L as well as new complete L and R driveshafts. My clutch has been slipping for the past 3000 kms!, and the CV's click in all directions when in 4WD....and have been for a year now.
I'm wondering if there is anything else that should be checked out when this job is done? Are there any particular seals or hard to reach parts that will become accessible during this proceedure? The motor has about 100 000 miles on it. I have been quoted a price of $1400 CAN to do the job, does this seem reasonable? The clutch alone was going to be $1000, and since it will be out, they said an additional $400 for the drive shafts.
92 Mighty Max V6 4x4 SWB
32's, torsion lift, yota lift shackles in the back, rear LSD, 4.22's
safari rack, 3" body lift
85 VW Westfalia Baja beast
1975 HONDA CB500T cafe racer
Sector 9 pintail
Re: New clutch and front drive shafts...what else to check? [Re: shorepig] #986130 02/18/10 07:16 AM
Needle bearing in the steering knuckles, LF drive axle seal, brake hoses, trans/t-case mount, slave cylinder, wiring connectors, etc.
Re: New clutch and front drive shafts...what else to check? [Re: shorepig] #986131 02/18/10 07:54 AM
4ePikanini Offline
if the clutch is replaced I would have the following replaced as well.
freeze plugs on the back part of the engine
thrust bearing
spigot bearing
overhaul clutch cylinder
if you are doing the sideshafts then do the balljoints at the same time.
Karma's Law - For every action there is a multiplied reaction!
93 Pajero GLS 3.0 V6 LWB - SOLD
2001 Gen3 Di-D LWB - SOLD
2005 Touareg R5 2.5 TDi
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.5963 MB (Peak: 0.6502 MB) Data Comp: Off Server Time: 2026-06-07 03:13:06 UTC
