cam broke in half #986265 02/19/10 02:52 AM
tomr406 Offline OP
In my 22r my cam broke in half. I was woundering if it happean to anyone else.
Re: cam broke in half [Re: tomr406] #986266 02/19/10 02:57 AM
kewlynx Offline
For me, that's a first since the advent of the Internet. <img src="/forums/images/graemlins/scared.gif" alt="" />
If EB's in for the weekend, he might chime in; he's had a lot of beatup 22R cores roll in.
How about some history on that engine?
**ubi apis- ibi salus**
Re: cam broke in half [Re: tomr406] #986267 02/19/10 03:08 AM
Adam F Offline
I've seen cams break in a handful of engines at work. No Toyotas though. We usually just replace them and keep on running the motor with no problems.
97 4R, stock, daily driver
Re: cam broke in half [Re: kewlynx] #986268 02/19/10 03:14 AM
tomr406 Offline OP
the truck has 135,000 on the truck, weber carb,5 speed and was maintain well. how it happean.... I went down to the dump. air temp...32f.. I stopped at the stop sign and went to take off and heard a clunck...that was the end of the cam.. The dump ass behind the wheel drove home on two cyclinders...took the valve cover off and there was normal oil sitting on top of the head.
Re: cam broke in half [Re: tomr406] #986269 02/19/10 04:42 AM
Ralph Offline
I recommend http://www.engnbldr.com/
Their RV cam is nice, but I've wondered about their Crawler cam.
This could be the perfect time to upgrade as long as you don't install some wild A** cam in.
Ralph
1991 Toyota 4x4 Standard Cab Pickup.
engnbldr cam and head.
Doug Thorley Headers
Home Made Cat Backs
30x9.5x15 BF Goodrich All-Terrain M/T KM2
Re: cam broke in half [Re: Ralph] #986270 02/19/10 06:37 AM
DRTDEVL Offline
It actually happened to an old member here (no longer posts) named dieselshop. I saw the cam myself.
He was just driving to work in the morning and heard a pop. Engine running on two cylinders. He turned it around and drove home.
Lucky for him we had just finished rebuilding a junkyard 22RE to throw inside after he saw my rod bearing let go.
Re: cam broke in half [Re: DRTDEVL] #986271 02/19/10 08:53 PM
bodyswapped8789 Offline
The only time a saw a cam brake in a toyota was from not changing the oil. It was a lexus and the lady never changed the oil ever. The car had 90k on it. After taking the valve cover off it was so full of sludge. Then she brings our loaner car back with a dog terd on the leather back seat. Dirty B***h.
89 V6 manual trans Dodge Raider frame 87 cold weather pkg 2" body lift, Soft 8's wraped in BFG km2 33x10.5x15, JDM Pajero yellow Bosch fogs. Yackama basket. Duel bouncies gen II rear springs,gen II ft brakes,master and booster.
Re: cam broke in half [Re: tomr406] #986272 02/20/10 12:02 AM
engnbldr Offline
>>>*I have seen perhaps a dozen cases all told, without fail we find a badly warped head. In operation the cam flexes, a bit like bending a beer can back and forth.
In that situation, she will break. A casting flaw is always a possible, but normally the evidence of the cause is obvious.
I saw one actually worn in half once, the oil galley plugged and tore up the rockers and cam lobes and the owner drove her until she stopped. That one snapped when the arm was actually cutting into the base circle.
*Most engines would have died and gone to China for melting down into flapjack turners, on just two cylinder the guy kept right on going. I remember I asked him how long it had run that way, he answered "Huh?"....*LOL**
If the cam line checks out straight, pull the head and fix the bent valves and go back to driving. If bent, the cam line will need to be remachined or the head replaced....*EB
*Beats the he** outa me!....*LOL**...
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.006s) Memory: 0.6254 MB (Peak: 0.7238 MB) Data Comp: Off Server Time: 2026-10-22 07:41:18 UTC
