Page 1 of 3 1 2 3
Pulls to right when in 4wd? #986785 02/21/10 11:21 PM
RogerH Offline OP
I recently had ARB lockers installed front and rear and also Gearmaster low range transfer gears. Since then when I am engaged in 4wd on the road the truck pulls to the right significantly. Could this be caused by wrong fluids, lube or something else? 2000 Montero Thanks!
2000 Montero, ARB bumper, TJM snorkle, OME suspension, Maggiolina Extreme RTT, BFG KM2's 33/10.5/15. ARB fr/rear lockers, 3.15 transfer case.
Re: Pulls to right when in 4wd? [Re: RogerH] #986786 02/22/10 01:07 AM
How about front end alignment?
Re: Pulls to right when in 4wd? [Re: rxinhed] #986787 02/22/10 01:19 AM
RogerH Offline OP
It drives straight and true when in 2wd, its when I engage 4H that it pulls. Would being out of alignment effect it when only in 4wd?
Thanks!
Re: Pulls to right when in 4wd? [Re: rxinhed] #986788 02/22/10 01:20 AM
plh Offline
When my hubs are locked in, I also pull pretty hard to the right. I have an LSD installed front & rear with Mobile 1 lube. No modifier.
  • '83 Might Max: IG @83mmax
  • '88 Raider: my OG
  • '89 Raider: rescued
  • '92 RS M/T: sold
  • '93 SR: sent to crusher
  • '05 Montero LTD: sold
  • '18 PHEV: wife's daily
  • '14 OL GT
  • http://www.tuffpans.com
Re: Pulls to right when in 4wd? [Re: plh] #986789 02/22/10 01:22 AM
RogerH Offline OP
These are the auto hubs and never did this before (102,000 miles) I can live with it, I was just hopeful nothing was getting damaged.
Thanks!
Re: Pulls to right when in 4wd? [Re: RogerH] #986790 02/22/10 01:31 AM
RigilKent Offline
is it possible that your front left shaft isnt engaging that could explain the pulling
84' Montero 2.6L SWB
Re: Pulls to right when in 4wd? [Re: RigilKent] #986791 02/22/10 01:40 AM
StockRaider Offline
does it pull when the lockers are not engaged?
Richard E
1989 Montero - Stock-ish
1983 Honda XL600R
Re: Pulls to right when in 4wd? [Re: StockRaider] #986792 02/22/10 01:47 AM
RogerH Offline OP
Yes it pulls when lockers are not engaged. We had some snow this weekend here in Colorado and when I put it into 4H it pulls to the right. Both fronts are engaging.
Re: Pulls to right when in 4wd? [Re: StockRaider] #986793 02/22/10 02:30 AM
Jack up both front wheels and rotate the cv axles and see if the autohubs are locking up. Sounds just like my 95sr when the front axle disconnect doesn't disco when I shift to 2wd. I get a strong pull to the right then.
Re: Pulls to right when in 4wd? [Re: fasteddy] #986794 02/22/10 03:03 AM
RogerH Offline OP
Thanks! I'll give it a try.
Page 1 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.006s Queries: 16 (0.004s) Memory: 0.6377 MB (Peak: 0.7441 MB) Data Comp: Off Server Time: 2026-05-29 23:54:23 UTC
