Regular or premium? #986810 02/22/10 04:48 AM
L
Leadfoot Offline OP
What fuel should I use in a 1998 Montero 3.5 SOHC?
Premium or regular? I don't have the owner's manual.
Montero 1998/Land Rover 1997/FJ Cruiser 2007
Re: Regular or premium? [Re: Leadfoot] #986811 02/22/10 05:32 AM
What does the sticker inside the fuel filler door say?
Re: Regular or premium? [Re: off-roader] #986812 02/22/10 05:48 AM
Red1979 Offline
I am trying to figure this out too as I know it says regular but if I use it I have a spark knock. premeium does away with it. But I have a few things I think needs replacing so I am working on it now
1987 Dodge Ram 50
2.6 5 speed
2 inch body lift 31x11.50 Swamper LTBs
4.62 gears lsd rear and welded front with lockouts
Weber carb waiting to be installed
Re: Regular or premium? [Re: Leadfoot] #986813 02/22/10 06:29 AM
Grasscat Offline
"Regular" per the Manual and TBS
Michael j
TreadLightly! Trainer
Re: Regular or premium? [Re: Leadfoot] #986814 02/22/10 07:18 AM
Kevin C Offline
The new question should be : I have a motor that supposed to run on regular, but it pings. What should I do?
Kevin
Re: Regular or premium? [Re: off-roader] #986815 02/22/10 06:32 PM
L
Leadfoot Offline OP
It says "unleaded fuel only". I guess that means regular, However my FJ Cruiser says the same thing on filler door but the manual says premium. I don't have a manual for the Montero.
Re: Regular or premium? [Re: Grasscat] #986816 02/22/10 06:42 PM
L
Leadfoot Offline OP
Thanks. That is what I was looking for.
Re: Regular or premium? [Re: Leadfoot] #986817 02/22/10 06:49 PM
StockRaider Offline
I am sure Premium is recommended, but the engine has the ability to run regular just fine. My 01 Outback says premium but I ran 87 since I bought it and not a single ping knock or problem.
Richard E
1989 Montero - Stock-ish
1983 Honda XL600R
Re: Regular or premium? [Re: StockRaider] #986818 02/22/10 08:34 PM
Grasscat Offline
I am sure Premium
Not so See this post
Michael j
Re: Regular or premium? [Re: Kevin C] #986819 02/22/10 09:19 PM
L
Leadfoot Offline OP
Kevin
Check the timing. An engine made for running on regular, if run on premium, to get any advantage of the higher octane needs to run at slightly different time. But when you pour regular into it, it pings. If it pings with regular but not on premium, retard the timing. That is only true if the engine is made to run on regular.
PHP: 7.4.33 Page Time: 0.006s Queries: 16 (0.004s) Memory: 0.6407 MB (Peak: 0.7644 MB) Data Comp: Off Server Time: 2026-05-26 04:58:20 UTC
