Rear end Swap.. Need info please #986922 02/23/10 01:24 AM
brubren3815 Offline OP
The 93 has died and I want to swap the 93 to the 95.. the 95 seems to be making a noise from the rear. Don't think its coming from the diff. You can hear it when you drive by parked cars or are close by a building. I makes a sound like"ssshhhhhh" Bearings??? The 93 is SILENT and seems in great shape..How do you check these things? Oil level is ok..Can u-joints make a sound like this? the sound is there on or off the gas. How hard is it to swap these out and is there a search item for it... Thanks!
2002 XLS /LSD/Thule Rack /PIAA Extreme White headlamps /K+N system/Michelin LTX MS--KYB gas-adjust all around
95 LS-- Dual Bouncy Seats 234k and still rockin'
Re: Rear end Swap.. Need info please [Re: brubren3815] #986923 02/23/10 02:23 AM
LRJ4x4 Offline
sounds like wheel bearings to me.
Re: Rear end Swap.. Need info please [Re: LRJ4x4] #986924 02/23/10 03:06 AM
sparkem Offline
Make sure they have the same gears ratio.
Re: Rear end Swap.. Need info please [Re: sparkem] #986925 02/23/10 03:51 AM
ryany Offline
Could be coming from your brakes also. Have someone else in the vehicle stick their head out the window while you drive slowly and see if they can tell which wheel the noise is coming from - that'll at least give you a location to start looking. Then you can jack up that corner and rotate the wheel by hand and try to determine where the noise is coming from. It could be something as simple as a rock caught in the brakes or the brake backing plate making contact with the rotor after having been bent by hitting something in the road.
At the very least it'll give you more info to post for suggestions. <img src="/forums/images/graemlins/wink.gif" alt="" />
95 Montero SR
Re: Rear end Swap.. Need info please [Re: ryany] #986926 02/24/10 12:50 AM
Thanks for the tips.. Its raining now so the next dry day I'll give it a go. Hope it is the brakes!
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6067 MB (Peak: 0.6713 MB) Data Comp: Off Server Time: 2026-10-24 07:18:40 UTC
