89 Raider Grille #986963 02/23/10 03:19 PM
shadytree Offline OP
So my wife destroyed a 96 GMC full size pickup with my Raider 3 years ago right before we went to Japan...Bent the A/C Condenser, destroyed the grille/bumper, lower valance. Should see the damage to the GMC...my damage was "minor" LOL! I've been looking for a Grille but I won't pay the $200+ from the online Mitsubishi catalog. I found a site called brandywineparts. Does anyone have experience with them? They show under "new parts" a grille for less than $20, but under "used parts" they list one for $40????? I'm not sure what to think because they don't have a pic for the new one that is cheaper...Any thoughts? Can't find any in the Va. Beach area where I'm in training w/ the Army for the next few months....
89 Raider 3.0L V6
Re: 89 Raider Grille [Re: shadytree] #986964 02/23/10 04:25 PM
FrankR Offline
Unless you're partial to the '89 original grille, I'd suggest considering the earlier style.
I replaced the grille on my '89 with the older style because there is greater flow area on the earlier grilles..... IIRC, the '88 grill has about 20% more open space than the '89. What is available on the '89 may be plenty, but I like the idea of more radiator exposure.
Auction
Frank
Re: 89 Raider Grille [Re: shadytree] #986965 02/23/10 04:50 PM
ryany Offline
What you're probably seeing is a new aftermarket grille - not OEM Mitsubishi. The aftermarket parts can be really hit or miss on their quality and fitment. During my years in a bodyshop we would avoid aftermarket whenever possible, preferring used OEM parts instead - at least they would fit properly.
95 Montero SR
Re: 89 Raider Grille [Re: ryany] #986966 02/23/10 05:17 PM
look up a new 83-84 grille, those are the stamped steel ones. I hear they are cheaper at the dealer. Those are the best looking I think. If you go aftermarket search long and hard for the grille with the foglight holes <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: 89 Raider Grille [Re: FrankR] #986967 02/23/10 05:38 PM
Thanks for the heads up on everything. I'm definitely looking to go OEM. Are the 87/88 direct fits? Or should I expect to modify it? I would venture to guess that the size is the same...
89 Raider 3.0L V6
Re: 89 Raider Grille [Re: shadytree] #986968 02/23/10 06:44 PM
FrankR Offline
They are a direct fit.
Frank
Re: 89 Raider Grille [Re: FrankR] #986969 02/23/10 07:26 PM
I have a selection of grilles...
Re: 89 Raider Grille [Re: rxinhed] #986970 02/24/10 01:10 AM
Temple Offline
I just built my own out of expanded metal......... painted it flat black. I think it gives the raider the dont pull out infront of me look that everyone one needs. well at least in Virginia! <img src="/forums/images/graemlins/kewl.gif" alt="" />
"No obstacle brute force and ignorance cant overcome"
89 SWB RAIDER (IN PIECES)
06 F250 SuperDuty Axles
Currently saving for F-O-A 18" Coilovers
Cummins 6bta/5r110w/np271
Re: 89 Raider Grille [Re: Temple] #986971 02/24/10 02:16 AM
Kevin C Offline
Just make sure you use the correct piant.
Correct flat black piant for your grill
Kevin
Re: 89 Raider Grille [Re: Kevin C] #986972 02/24/10 02:56 AM
Temple Offline
Kevin
LOL>.............Love it!!
Cruising and Cooking! <img src="/forums/images/graemlins/kewl.gif" alt="" />
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.004s) Memory: 0.6427 MB (Peak: 0.7668 MB) Data Comp: Off Server Time: 2026-06-09 23:14:11 UTC
