89 Raider Grille
#986963
02/23/10 03:19 PM
So my wife destroyed a 96 GMC full size pickup with my Raider 3 years ago right before we went to Japan...Bent the A/C Condenser, destroyed the grille/bumper, lower valance. Should see the damage to the GMC...my damage was "minor" LOL! I've been looking for a Grille but I won't pay the $200+ from the online Mitsubishi catalog. I found a site called brandywineparts. Does anyone have experience with them? They show under "new parts" a grille for less than $20, but under "used parts" they list one for $40????? I'm not sure what to think because they don't have a pic for the new one that is cheaper...Any thoughts? Can't find any in the Va. Beach area where I'm in training w/ the Army for the next few months....
89 Raider 3.0L V6
Re: 89 Raider Grille
[Re: shadytree]
#986964
02/23/10 04:25 PM
Unless you're partial to the '89 original grille, I'd suggest considering the earlier style. I replaced the grille on my '89 with the older style because there is greater flow area on the earlier grilles..... IIRC, the '88 grill has about 20% more open space than the '89. What is available on the '89 may be plenty, but I like the idea of more radiator exposure. Auction Frank
[Re: shadytree]
#986965
02/23/10 04:50 PM
What you're probably seeing is a new aftermarket grille - not OEM Mitsubishi. The aftermarket parts can be really hit or miss on their quality and fitment. During my years in a bodyshop we would avoid aftermarket whenever possible, preferring used OEM parts instead - at least they would fit properly.
95 Montero SR 3.8 MIVEC, Advance headers, 2 1/2" exhaust, Magnaflow muffler, OME shocks & rear springs, 2" body lift, 3" tank lift, 4.90s, TRE front locker, factory rear locker, Roger Brown Rock Sliderz, 315/75r16 (35") tires, Sport big brakes
[Re: ryany]
#986966
02/23/10 05:17 PM
look up a new 83-84 grille, those are the stamped steel ones. I hear they are cheaper at the dealer. Those are the best looking I think. If you go aftermarket search long and hard for the grille with the foglight holes <img src="/forums/images/graemlins/kewl.gif" alt="" />
[Re: FrankR]
#986967
02/23/10 05:38 PM
Thanks for the heads up on everything. I'm definitely looking to go OEM. Are the 87/88 direct fits? Or should I expect to modify it? I would venture to guess that the size is the same...
89 Raider 3.0L V6
[Re: shadytree]
#986968
02/23/10 06:44 PM
They are a direct fit.
Frank
[Re: FrankR]
#986969
02/23/10 07:26 PM
I have a selection of grilles...
[Re: rxinhed]
#986970
02/24/10 01:10 AM
I just built my own out of expanded metal......... painted it flat black. I think it gives the raider the dont pull out infront of me look that everyone one needs. well at least in Virginia! <img src="/forums/images/graemlins/kewl.gif" alt="" />
"No obstacle brute force and ignorance cant overcome" 89 SWB RAIDER (IN PIECES) 06 F250 SuperDuty Axles Currently saving for F-O-A 18" Coilovers Cummins 6bta/5r110w/np271
[Re: Temple]
#986971
02/24/10 02:16 AM
I just built my own out of expanded metal......... painted it flat black. I think it gives the raider the dont pull out infront of me look that everyone one needs. well at least in Virginia! <img src="/forums/images/graemlins/kewl.gif" alt="" /> Just make sure you use the correct piant. Correct flat black piant for your grill Kevin
[Re: Kevin C]
#986972
02/24/10 02:56 AM
I just built my own out of expanded metal......... painted it flat black. I think it gives the raider the dont pull out infront of me look that everyone one needs. well at least in Virginia! <img src="/forums/images/graemlins/kewl.gif" alt="" /> Just make sure you use the correct piant. Correct flat black piant for your grill Kevin LOL>.............Love it!! Cruising and Cooking! <img src="/forums/images/graemlins/kewl.gif" alt="" />
