3.4L gm motor for trooper swap - machined and partially assembled (pics) #986976 02/23/10 05:00 PM
johnny37v Offline OP
3.4L L32 RWD - block was part of an Isuzu Trooper project
-block was cleaned / magnaflux-d / new freeze plugs installed
-crank was polished - new bearings - I installed
-new pistons are on original gm rods - rings and rod bearings included (not assembled)
-new cam bearings installed
included:
-2.8 multiport F/I intake (rough...never cleaned it up), i'm not sure this would even work...I thought it would be a cool alternative to the stock tbi setup
-it's on the engine stand which would be included
$900 Petaluma, CA...must be picked up
John
[Pm for phone number]
Re: 3.4L gm motor for trooper swap - machined and partially assembled (pics) [Re: johnny37v] #986977 02/24/10 06:11 PM
JohninLV Offline
Was the block bored? What is the oversize?
Thank You
John In LV
3 90 Trooper V-6's, 5 speed, 4.3L TBI, 31" BFG AT's, Fender Flairs, Bored intake, 1.6 roller rockers, MSD Coil, Jacobs Omni ignition. Heavy duty torsion bars, Rancho 9000 Shocks CAN'T SPELL, TO OLD TO LEARN, GOD BLESS YOU IF YOU CAN.
Re: 3.4L gm motor for trooper swap - machined and partially assembled (pics) [Re: johnny37v] #986978 02/24/10 07:24 PM
87Montero Offline
This is exactly what I want, but too far away. <img src="/forums/images/graemlins/frown.gif" alt="" />
Re: 3.4L gm motor for trooper swap - machined and partially assembled (pics) [Re: JohninLV] #986979 02/24/10 07:39 PM
I'm going to my storage unit to see if I can find some markings on the pistons to see if they're over. The receipt from my machinist up in Portland is long gone. He set it up for me as kind of dummy proof and built for reliability/longevity vs. power. I've also got a box of fasteners and the original cam that came out...not sure if it's worth salvaging or not. I'm pretty sure it was bored out a bit, the camaro it came out of had over 80K on it.
thx
Re: 3.4L gm motor for trooper swap - machined and partially assembled (pics) [Re: johnny37v] #986980 02/24/10 08:36 PM
the marking on top of piston says .75mm...hope that (or the picture helps)
Thanks.
jv
Re: 3.4L gm motor for trooper swap - machined and partially assembled (pics) [Re: johnny37v] #986981 03/13/10 07:58 PM
bump for lower price - $800, emoticon for throwing up/sick to my stomach here.
Re: 3.4L gm motor for trooper swap - machined and partially assembled (pics) [Re: johnny37v] #986982 03/13/10 10:02 PM
Oyaji_Jon Offline
PM sent
73
-Jon
KJ6GVM
As seen on Expedition with TX plates: VEGETARIAN - An old Indian word for poor hunter
Grampa's Trooper
1974 FJ40
1987 FJ60
Moderated by  4x4Wire, code33, kewlynx
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6181 MB (Peak: 0.6969 MB) Data Comp: Off Server Time: 2026-05-29 15:21:27 UTC
