how to attach new door glass to old clips/ frame mount #987060 02/24/10 03:44 AM
Hecubus Offline OP
My passanger door glass was busted out by some punk kids, so I bought a new window for $40. I didnt notice the new glass didnt have the mount on the bottom so I asume you can use the old one and use some kind of epoxy to glue it in place?
Can anyone help me out? I cleaned all the glass and old epoxy out of the old bracket, now I just need to properly install it on the new glass.
Thanks
88 SR5 Toyota Pickup 22re,TRD cam 4" Pro-comp, crappy superlift 4" springs rear, 1" body lift, 1.5" BJ spacers, 35x12.5 PJ Dirt grips, no locker yet =( SAS in the works
Re: how to attach new door glass to old clips/ frame mount [Re: Hecubus] #987061 02/24/10 04:11 AM
K_Raider Offline
I am having this same problem on my Dodge so I will be anxiously waiting on this answer also. <img src="/forums/images/graemlins/smile.gif" alt="" />
88 Raider- sitting on a full size Chevy frame with 35.5x11.50x16 Dyna Torque II tractors
89 Montero- stock 2.6 M/T 30-9.50 BFG all terrains on American Racing Wheels
99 2500 Ram- 285-75-16 Uniroyal all terrains,straight pipes with no cat (yes its loud)
Re: how to attach new door glass to old clips/ frame mount [Re: Hecubus] #987062 02/24/10 04:23 PM
toyrunner Offline
Thanks
I pulled the rubber insulator off the window bracket and used silicone to glue it to the window. I laid a small bead of silicone to the channel and then slid the window in place. The silicone was clear and ensured the window stayed put.
1985 SR5 4Runner
eLocked with Carter Lock
4.7:1 single case
Davez Offroad twin stick
Re: how to attach new door glass to old clips/ frame mount [Re: Hecubus] #987063 02/24/10 04:46 PM
6
69442 Offline
Thanks
Take your rig and glass parts to a local body shop and ask for assistance.
Most body shops up here (Seattle) are very friendly and don't mind giving advise as long as it doesn't turn into a long winded ordeal.
Re: how to attach new door glass to old clips/ frame mount [Re: Hecubus] #987064 02/24/10 04:56 PM
Cholltero Offline
The way to do it is to pull it apart , clean the rubber gasket real good (spread it open and wire brush it ) to get any rust / dirt out . When installing it on the new window , with the rubber in the channel, lube with a little soapy water and push onto the glass. When it dries it will grip just fine.
85' 4x4 e-cab flatbed 22r carb ((SOLD))
86' 4runner, 22re , "60 buck truck"
95' 4runner, 22re,5sd, last of the good ones
02' Tacoma prerunner, 2.7L, 5spd., 4x4
Re: how to attach new door glass to old clips/ frame mount [Re: Cholltero] #987065 02/24/10 05:15 PM
6
69442 Offline
I believe he's talking about the moveable glass ... right? If so, have somebody show you or you could break the glass and be out another $40
Re: how to attach new door glass to old clips/ frame mount [Re: 69442] #987066 02/25/10 12:22 AM
K_Raider Offline
Thats what I got out of his post. Thats the problem I'm having. Mine is the roll up drivers window.
Re: how to attach new door glass to old clips/ frame mount [Re: K_Raider] #987067 02/25/10 12:38 AM
6
69442 Offline
There's a fastener or fasteners that attaches to the bottom of the glass that fit to the regulator which moves the glass up and down.
The process of attaching this fastener needs to be done correctly or you'll have headaches for sure.
Since I can't show you myself, I suggest swinging by your local body shop so they can take 5 minutes to show you.
PHP: 7.4.33 Page Time: 0.011s Queries: 15 (0.008s) Memory: 0.6257 MB (Peak: 0.7211 MB) Data Comp: Off Server Time: 2026-10-24 03:24:55 UTC
