montero driveshaft
#987363
02/25/10 09:55 PM
Hey can i Pull oot the main driveshaft and run the engine? Will all the gear oil pour out the end of the tranny? Thanks
Re: montero driveshaft
[Re: hdmaster5312]
#987364
02/25/10 10:13 PM
I think it should be fine. why cant your run it in Neutral? Im pretty sure its sealed around the output shaft of the tranny. Someone will know for sure
84' Montero 2.6L SWB
[Re: hdmaster5312]
#987365
02/25/10 10:50 PM
Hey can i Pull oot the main driveshaft and run the engine? Will all the gear oil pour out the end of the tranny? Thanks Not sure what model vehicle you have (put it in your signature please) but the rear output of the transfer case is not sealed in a gen I/II v6. It's a slip yoke design. That said, if you remove the rear driveshaft, the gear oil does pour out. Not necessarily all of it but alot of it will for sure.
[Re: off-roader]
#987366
02/25/10 10:58 PM
I drove mine enough to move it in the driveway, but oil will come out of the t-case. As said above, not all of it, but more comes out with every incline. use caution.
'88 Raider. 2.6L dead...2.4L swap in progress, AT, 33's, 2 bouncy seat,AC, CC, 2.25 exh, 2" Tbar, 2" BL, rear DB, rear LSD,4.90's, SW hubs,gen2 uca's, KYB shocks, snorkel, elec fan, MSD.
'99 chev k3500 crewcab '15 Subaru XV '03 BMW i325
[Re: zarktheshark]
#987367
02/25/10 10:59 PM
yep see good thing you didnt listen to me
Re: montero driveshaft '92 rs with bad vibration
[Re: RigilKent]
#987368
02/26/10 12:01 AM
I guess I could try it in neutral.It's a 92 rs I have replaced all the front bearings, the u-joints all around, the rear wheel bearings and new tires and still undriveable due to a rear end vibration that I guess may be an out of balance driveshaft. I was going to drop the driveshaft and start it up and see if it was still there. I have about 6 months and about a grand in it and am going crazy now.
[Re: hdmaster5312]
#987369
02/26/10 01:02 AM
I run mine all the time without the rear driveshaft. Get one of those 2 inch diameter rubber plumbing caps with the hose clamp. I clean the tailpiece cover with some alcohol and use a very small ammoumt of grey silicon. Do not overtighten the clamp as the cap will pop off. Give the sealant time to dry. You''l be good to go. I have driveline problem and I have run like this several times for quite some time...
dave h. '89 Raider V6 5spd;Aisin Hubs;; Gen2 LS: frt. brakes, rear coils;U.C.arms;R.trailing arms;idler arm; rear LSD axle w.disc brakes ;2 battery system for Dog's fan; relocated ECU; custom bumpers;J.Baker receiver;Conferr roofrack; t-bar crank.
[Re: KrzyDav]
#987370
02/26/10 01:45 AM
I run mine all the time without the rear driveshaft. Get one of those 2 inch diameter rubber plumbing caps with the hose clamp. I clean the tailpiece cover with some alcohol and use a very small ammoumt of grey silicon. Do not overtighten the clamp as the cap will pop off. Give the sealant time to dry. You''l be good to go. I have driveline problem and I have run like this several times for quite some time... This is an awesome idea for a trailside repair. Can you post pictures?
[Re: LandRaider]
#987371
02/27/10 12:43 AM
Nope,,,I can't afford a P.C. (poverty is bondage). It's as simple as I described,,pull the slipyoke, pull of the dust can, wipe the oil off, silicone and "slightly" tighten clamp.
