montero driveshaft #987363 02/25/10 09:55 PM
hdmaster5312 Offline OP
Hey can i Pull oot the main driveshaft and run the engine?
Will all the gear oil pour out the end of the tranny?
Thanks
Re: montero driveshaft [Re: hdmaster5312] #987364 02/25/10 10:13 PM
RigilKent Offline
I think it should be fine. why cant your run it in Neutral? Im pretty sure its sealed around the output shaft of the tranny. Someone will know for sure
84' Montero 2.6L SWB
Re: montero driveshaft [Re: hdmaster5312] #987365 02/25/10 10:50 PM
Thanks
Not sure what model vehicle you have (put it in your signature please) but the rear output of the transfer case is not sealed in a gen I/II v6. It's a slip yoke design.
That said, if you remove the rear driveshaft, the gear oil does pour out. Not necessarily all of it but alot of it will for sure.
Re: montero driveshaft [Re: off-roader] #987366 02/25/10 10:58 PM
zarktheshark Offline
I drove mine enough to move it in the driveway, but oil will come out of the t-case. As said above, not all of it, but more comes out with every incline. use caution.
'88 Raider. 2.6L dead...2.4L swap in progress, AT, 33's, 2 bouncy seat,AC, CC, 2.25 exh, 2" Tbar, 2" BL, rear DB, rear LSD,4.90's, SW hubs,gen2 uca's, KYB shocks, snorkel, elec fan, MSD.
'99 chev k3500 crewcab
'15 Subaru XV
'03 BMW i325
Re: montero driveshaft [Re: zarktheshark] #987367 02/25/10 10:59 PM
RigilKent Offline
yep see good thing you didnt listen to me
Re: montero driveshaft '92 rs with bad vibration [Re: RigilKent] #987368 02/26/10 12:01 AM
I guess I could try it in neutral.It's a 92 rs I have replaced all the front bearings, the u-joints all around, the rear wheel bearings and new tires and still undriveable due to a rear end vibration that I guess may be an out of balance driveshaft. I was going to drop the driveshaft and start it up and see if it was still there. I have about 6 months and about a grand in it and am going crazy now.
Re: montero driveshaft '92 rs with bad vibration [Re: hdmaster5312] #987369 02/26/10 01:02 AM
KrzyDav Offline
I run mine all the time without the rear driveshaft.
Get one of those 2 inch diameter rubber plumbing caps with the hose clamp. I clean the tailpiece cover with some alcohol and use a very small ammoumt of grey silicon.
Do not overtighten the clamp as the cap will pop off.
Give the sealant time to dry. You''l be good to go.
I have driveline problem and I have run like this several times for quite some time...
dave h.
Re: montero driveshaft '92 rs with bad vibration [Re: KrzyDav] #987370 02/26/10 01:45 AM
LandRaider Offline
This is an awesome idea for a trailside repair. Can you post pictures?
Re: montero driveshaft '92 rs with bad vibration [Re: LandRaider] #987371 02/27/10 12:43 AM
KrzyDav Offline
Nope,,,I can't afford a P.C. (poverty is bondage).
It's as simple as I described,,pull the slipyoke, pull of the dust can, wipe the oil off, silicone and "slightly" tighten clamp.
dave h.
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6300 MB (Peak: 0.7343 MB) Data Comp: Off Server Time: 2026-05-29 23:48:22 UTC
