Welded! #987546 02/27/10 04:04 AM
TayJ Offline OP
So, Toasty talked me into it, he has been trying for a year or more. I welded up my rear d44.
I did it just how he told me. I welded the spider gears together and then put plate steel in the middle section of all the spider gears and welded them to the plate. Nice and solid. Plated both sides. He said dont welded to the carried because welding to cast steel can cause cracks and weak points.
Some things I would like to point out to others who are going to attempt this later:
1. Make sure you clean really well before hand. I did and it showed.
2. Make sure you clean really well after you get done welding. Its a good idea to get as much slag out as you can. (you spend a long time cleaning before you weld, a couple minutes welding and then a ton of time cleaning after you weld!)
3. When you drain your gear oil into a oil pan and then leave the same oil pan under the axle to catch the three cans of brake clean you use to clean out the axle, make sure you remove it before you start welding. This is the one thing I didn't do correctly. Brake clean catches fire fast and then the oil keeps burning. Bad! Oh and water wont put that fire out. I ended up just smothering the fire. I was successful in dragging the fire out from under my jeep though!
All in all....it has so far not been a great street upgrade. We will see tomorrow how it does offroad!
Jeep
Jus' sayin'
Re: Welded! [Re: TayJ] #987547 02/27/10 07:54 AM
welcome to the world of locked diff, good job. A little secret to make cleanup a snap, spray dry graphite lube all over everything after you clean all the oil out, once the graphite dries (almost instantly you can watch it happen) lightly wipe it with a non abrasive rag or papertowel. Don't wipe it off just kinda polish it shiny. Once it's all shiny weld it up like normal, you can weld through it without getting porosity but the splatter won't stick. Once your all done just spray it out you might have one or two little spots you'll need to scrape but thats it. The graphite can stay inside too it won't hurt anything.
Re: Welded! [Re: TOASTY] #987548 02/27/10 05:57 PM
TayJ Offline OP
Well darn, I bet even if I knew that prior to welding I still wouldn't have gotten the graphite.
Jeep
Jus' sayin'
Re: Welded! [Re: TayJ] #987549 02/27/10 06:26 PM
Porosity, Toast.
And there always seems to be a detail or two Mr. Toast seems to forget to tell you until you're done. I guess that way you'll REALLY remember it next time.
Good job, Tay. Hope it holds together all solid-like.
Re: Welded! [Re: JohnnyBfromPeoria] #987550 02/28/10 09:00 AM
TayJ Offline OP
Oh man! Just got home, 12:58am. Been out testing the welded rear out and I think its awesome! Helps out a ton, I can now carry my front tires into the air!!! Time for bed though....
Jeep
Jus' sayin'
Moderated by  4x4Wire, TOASTY
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.005s) Memory: 0.6081 MB (Peak: 0.6740 MB) Data Comp: Off Server Time: 2026-10-22 02:14:20 UTC
