A/T Temp Light came on.
#987650
02/27/10 05:55 AM
Hi everyone, My A/T light came on today about 5 minutes after I started the engine. It seems to fade in and out when I am driving. The outside temp is about 10 degress F. I am not puling anthing. The only thing I did different today was I took the Monty to a automatic car wash. Maybe something is wet? I am not sure where the A/T temp sensor is located on the transmission.
I did shut the engine off for about 30 minute. When I started the engine again the light came back on about 2 minutes after engine start. I checked the fluid level and it is ok.
Any idea's
1993 Montero SR 205,936 miles. BF Goodrich A/T's Dual Bouncy Seats.
Re: A/T Temp Light came on.
[Re: Troy24]
#987651
02/27/10 06:12 AM
You get them wet and they turn on. The sensor is on the passenger side of the tranny, in the cooler line. I'd take the connector loose and hit it with wd40 and seal it up with rtv sealant.
[Re: fasteddy]
#987652
02/27/10 06:18 AM
Thanks for the quick reply. I will check that out in the morning.
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.5940 MB (Peak: 0.6473 MB) Data Comp: Off Server Time: 2026-06-09 23:33:54 UTCValid HTML 5 and Valid CSS
