Help Power Steering/Gear Box Hose #988279 03/03/10 09:25 PM
N
NickR Offline OP
Sending out an SOS to SoCal members, i'm in the middle of swapping in the Gen II gear box and my power stering return hose tread is damaged. It's the one item holding me back from completing the project, with out it i can't go to TDS <img src="/forums/images/graemlins/frown.gif" alt="" />. I know i can pick one up at the JY but i'm stuck at work <img src="/forums/images/graemlins/frown.gif" alt="" />. Let me kow and we can meet up tonight or Thursday night <img src="/forums/images/graemlins/cheers.gif" alt="" />.
Thanks,
Nick
1987 Dodge Raider, stick on 33", 2.5" BL, Con-ferr roof rack, Hella driving lights & pencil beam lights.
Stuff collecting dust in the garage
SR Axle
LSD 3rd member
Early Gen 1 Bouncy seat
Early Gen 1 two piece rear bumper
2 sets of SWB Gen I rear seat-belts.
Set of Aisin Hubs.
Re: Help Power Steering/Gear Box Hose [Re: NickR] #988280 03/04/10 08:39 AM
N
NickR Offline OP
Got it fix, busted out the dremel and recreated the tread pattern. Next time I'm at the JY i'm going to stock up since it's a dealer only item and they wanted something like $130 special order.
SR Axle
LSD 3rd member
Set of Aisin Hubs.
Re: Help Power Steering/Gear Box Hose [Re: NickR] #988281 03/04/10 03:18 PM
Kevin C Offline
Do you have the box mounted yet?
Re: Help Power Steering/Gear Box Hose [Re: Kevin C] #988282 03/04/10 06:18 PM
Grasscat Offline
From reading his above post, I'd bet money on it. <img src="/forums/images/graemlins/smile.gif" alt="" />
Michael j
TreadLightly! Trainer
Re: Help Power Steering/Gear Box Hose [Re: Grasscat] #988283 03/04/10 06:29 PM
Kevin C Offline
I'm glad you were able to clear that up. As usual your insightful input has been very helpful. <img src="/forums/images/graemlins/lol.gif" alt="" />
I'm mostly curious if he ran into the same mounting hole problem that I had on the upper pair of bolts, and what his solution to it was.
Kevin
Re: Help Power Steering/Gear Box Hose [Re: Kevin C] #988284 03/05/10 12:35 AM
N
NickR Offline OP
Kevin
Kevin if your talking about the mounting holes from the gear box to the frame, I had to enlarge the holes on the gear box, I don't recall the drill bit size. Only 3 of the 4 holes after enlarging will line up. After tightening everything up I realized I could of probably used a different combination of holes to help easy the angle on the coupler, since I have a body lift on my truck. I'll post a picture later to better explain it.
SR Axle
LSD 3rd member
Set of Aisin Hubs.
Re: Help Power Steering/Gear Box Hose [Re: NickR] #988285 03/05/10 01:08 AM
Kevin C Offline
The box on the right is the late model unit. It has a faster steering ratio and larger guts. The upper mounting holes are also a bit further apart.
I was curious what you had done. On mine I opened the upper holes up on a mill. And used some custom washers as load spreaders. That kept the box and the pitman arm in the original location. If you rotate the box it changes the location of the pivot point where the box connects to the drag link. That will cause bump steer: a change in toe as the suspension moves up and down.
Kevin
Re: Help Power Steering/Gear Box Hose [Re: Kevin C] #988286 03/05/10 01:20 AM
87Montero Offline
Kevin
How would the box rotate if the bottom holes are not modified at all?
Re: Help Power Steering/Gear Box Hose [Re: 87Montero] #988287 03/05/10 01:24 AM
Kevin C Offline
Kevin
But he did modify the holes and one of the top holes does not line up. So.... I jumped to the conclusion the the box was rotated. The other clue was the steering coupler issue.
Kevin
Re: Help Power Steering/Gear Box Hose [Re: Kevin C] #988288 03/05/10 02:11 AM
N
NickR Offline OP
Kevin
Kevin
Kevin I did not rotate the gear box, I thought about rotating it after everything was in, to ease the coupler position. But I did not want tear everything down since it fit fine. I thought about drilling out the hole like on your picture but was to lazy/tired.
SR Axle
LSD 3rd member
Set of Aisin Hubs.
PHP: 7.4.33 Page Time: 0.015s Queries: 16 (0.012s) Memory: 0.6460 MB (Peak: 0.7722 MB) Data Comp: Off Server Time: 2026-07-17 07:51:04 UTC
