Gen2 UCA swap help
#988637
03/06/10 11:47 PM
Is there a writeup for the gen2 uca to gen1 swap? I searched and searched and couldn't find it.
Also I understand longer bolts may be required for this. Is there a concensus on what size bolt is needed?
Eric 89 Raider V6, 35s, 5sp, welded rear, 8k winch 89 Raider 2.6 going on 84 4runner frame
Re: Gen2 UCA swap help
[Re: SandRaider]
#988638
03/07/10 12:12 AM
I " almost" needed longer bolts. I used 1 thick and one thin shim on each arm. If I needed any more shimming I would have needed longer bolts. I didn't use the original lockwashers, the mistu washers are 2 times thicker than washers for NAPA. Doing that helped alot. I had to use the brake hose brakets off the gen 1 arms on the "new" gen 2 arms. Can't think of any more problems doing this swap, all pretty easy job.
dave h. '89 Raider V6 5spd;Aisin Hubs;; Gen2 LS: frt. brakes, rear coils;U.C.arms;R.trailing arms;idler arm; rear LSD axle w.disc brakes ;2 battery system for Dog's fan; relocated ECU; custom bumpers;J.Baker receiver;Conferr roofrack; t-bar crank.
PHP: 7.4.33 Page Time: 0.005s Queries: 15 (0.003s) Memory: 0.5901 MB (Peak: 0.6377 MB) Data Comp: Off Server Time: 2026-05-26 04:55:46 UTCValid HTML 5 and Valid CSS
