HELP!!! OBDII software/cable recomendations!!! #988646 03/07/10 07:51 AM
CORunner93 Offline OP
So.....5 years down the road (aka after the 3.4L motor swap) my 93 "ShagRunner" has failed emission.....mostly cause the EPA lowered the standards to ridiculously low levels, but to their credit I knew the thing always ran a little rich.
Anyway....I know everything is working (i.e. I get no 'check engine light' or codes when I run basic tests). So I want to dig a bit deeper and start looking into how well, and what, the specific sensors are doing (i.e, MAF, knock, timing, O2...ect).
So, I need to get a good (or adequate) OBDII software package. Does anyone have any recommendations? I'm looking for something I can load up on my laptop and connect to the OBDII system and see readings from the various sensors.
During some of the final testing of my motor swap I brought the truck to a shop and they put it up on their analyzer so we could see all the sensors working in a graphical format. That is the kind of thing I'm looking for. I know there are several cable/software packages out there....does anyone have any experience with or recommendations for these "tools"?
'93 4Runner - 3.4L 5VZ-FE, 2" body lift, on-board-air system, custom gauge cluster, rear e-locker, electric fan, custom built front and rear bumpers, sliders, 4,88 gears...all on 33x12.5's.
Re: HELP!!! OBDII software/cable recomendations!!! [Re: CORunner93] #988647 03/08/10 02:25 AM
kewlynx Offline
Couple links at the end of this article might be helpful to ya. If you've got a K&N on that thing, I'd see if the MAF is dirty first.
http://www.4x4wire.com/toyota/4Runner/tech/OBDII_ECU/
**ubi apis- ibi salus**
Re: HELP!!! OBDII software/cable recomendations!!! [Re: kewlynx] #988648 03/08/10 04:37 AM
Thanks kewlynx. I had read that article and checked out the links. There are a lot of different OBD2 "links" out there now though. some even claim to be able to write or "flash" to the ECU. I'm wondering if anyone has any experience with any of these.
Re: HELP!!! OBDII software/cable recomendations!!! [Re: CORunner93] #988649 03/08/10 01:59 PM
Dandeman Offline
Toyota Moderator
Toyota ECUs in general are not flashable by aftermarket tools. The 3.4 ECU is not flashable at all..
Re: HELP!!! OBDII software/cable recomendations!!! [Re: Dandeman] #988650 03/08/10 08:50 PM
Thanks for the reply Dandeman.
yeah....I found that out after several hours of internet research this weekend. Apparently , the newer ('05 maybe '04 and newer) ECU's are flashable. However, the few hours of reading I did on the subject did not make it sound simple, easy, or cheap. That will be a few more years down the road, it appears.
I ended up going with the OBDLink and ScanXL software package. That setup allows me to hook up to the ECU and display real time data from various sensors (hopefully).
Re: HELP!!! OBDII software/cable recomendations!!! [Re: CORunner93] #988651 03/10/10 06:33 PM
G
Greg_Canada Offline
Lots of people with 3.4's use this (BR3 scan tool)
http://www.obddiagnostics.com/
www.urdusa.com might sell it...
89 4Runner
Re: HELP!!! OBDII software/cable recomendations!!! [Re: Greg_Canada] #988652 03/12/10 04:48 AM
Adam F Offline
On a related note, I have a question. A friend of mine let me borrow his scan tool. Its a basic one, but it does do freeze frame info on a bunch of sensors. I hooked it up to my mom's 02 Outback and it gave me a bunch of good info on 02 sensors, various temps and other things. I hooked it up to my 97 4Runner and it never did give me any freeze frame info. Is my 97 not capable of this? I'd like to see what my 02 sensors are doing since my gas mileage is declining.
97 4R, stock, daily driver
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.6179 MB (Peak: 0.7087 MB) Data Comp: Off Server Time: 2026-07-10 12:20:15 UTC
