Whining noise from engine bay
#989417
03/11/10 06:35 AM
All,
Its been a while since Iv'e posted. I guess Rodeo's are such great vehicles that I have had few problems.
It was cold tonight in CA and I went out to get a pizza and I heard a high pitched whining noise coming from my engine bay. I shifted it into neutral and it did not go away and when i parked I looked in the engine compartment and it is definitely coming from there.
It was dark and I did not have access to any stuff but will use my stethoscope this weekend to search for the exact cause or area.
You all are so smart i thought that one of you might have seen this before,
I of course thought of alternator bearings, belts. etc. Does the cooling fan have its own set of bearings. It really did not sound like any bearings I have heard before which sound like screeching, this was more like a high pitched whine which increased when i opened the throttle.
Thanks in advance for any tips or advice.
your pal
98 Rodeo V6 69,000 miles
Rob
Rob Garven 98 Izusu Rodeo V6 4WD Auto 69,000 miles
Re: Whining noise from engine bay
[Re: robertgarven]
#989418
03/11/10 03:16 PM
IN my experience a bad fan clutch sounds more like a sort of grinding noise than a whirring. I associate whirring with the power steering pump (check fluid) as the most likely cause...beyond that you'll just have to sniff around. Does yours have a serp belt or v-belts? If you can't pin it down and you have individual v-belts you could pull them one at a time and see if the sound changes.
Steve Carlson - 95 Trooper LS expo rig Serenity now!
[Re: BigSwede]
#989419
03/11/10 04:34 PM
Or just wait until it warms up and see if the noise is still there. Like Bigswede said it is most likely your power steering pump. But I dont know how cold it gets where you live, but it could just be whining from the cold. When I lived in Chicago area, the winters there are freezing. And I use to come out of school hop in my trooper and the brake lines would be frozen and the steering pump would whine a little like your talking about. Sometime it just takes a while for the fluid to warm up, or maybe your pump is damaged now. Hope that helps
PHP: 7.4.33 Page Time: 0.009s Queries: 15 (0.007s) Memory: 0.5962 MB (Peak: 0.6505 MB) Data Comp: Off Server Time: 2026-11-03 13:36:38 UTCValid HTML 5 and Valid CSS
