Wiper realignment - how do I fix it? #989762 03/14/10 12:21 AM
87_Montero Offline OP
Searched the archives, but couldn't find this particular fix.
When replacing the windshield wiper motor, how do you position the wiper motor crank arm?
I've tried realigning the wiper motor crank arm and the wipers themselves about a dozen times but it always comes out wrong no matter what I do.
Every time I think everything is finally lined up right, the wipers stop in some weird position.
Thanks for your help!
DDs:
Projects: 86 Ram50
Re: Wiper realignment - how do I fix it? [Re: 87_Montero] #989763 03/14/10 02:14 AM
MarcDurant Offline
Take a look at the photos I posted here:
wipers at photobucket
You should be able to get pretty close by looking at the photos.
Worst case scenario, put the wiper motor back in as close as you can get it. Then run the wipers so you know the motor is in the "parked" position. Finally, remove the wiper arms and reposition them so they're in the right place.
89 Raider V6 manual
89 Montero 2-door Coupe "Super Legera"
91 Montero 4-door manual (Mint! Sunroof, cruise, power everything, BOUGHT FROM THE ORIGINAL OWNER!)
Re: Wiper realignment - how do I fix it? [Re: MarcDurant] #989764 03/14/10 03:02 PM
That's an amazing set of photos!
Thanks a ton for planning this set of photos, and posting them so people can learn from them.
It might be that the linkages need to be lubricated.
I'll let you know what happens.
DDs:
Projects: 86 Ram50
Re: Wiper realignment - how do I fix it? [Re: 87_Montero] #989765 03/15/10 03:02 AM
builthatch Offline
this might help too - alot of gen 1 wiper questions lately <img src="/forums/images/graemlins/wink.gif" alt="" />
http://www.4x4wire.com/forums/showflat.p...&PHPSESSID=
'87 swb 5spd 2.6L Montero, >150k miles. Pretty much bone stock as purchased from user ToddStidham1, 'cept some Hella 500's, 700's and Hella ECE headlight conversions.
6'4", 315lbs
Re: Wiper realignment - how do I fix it? [Re: 87_Montero] #989766 03/15/10 02:51 PM
MarcDurant Offline
Here's the photo you want to look at - this is the position of my wiper motor arm in the "parked" position.
Oops! Well, here's how the linkage connects to the motor.
89 Raider V6 manual
Re: Wiper realignment - how do I fix it? [Re: MarcDurant] #989767 03/16/10 01:49 PM
Hooray! It's working great now!
I pulled out the entire mechanism and lubricated everything.
I had to experiment with the resting positions of the control rods and the crank arm. If a 20-year-old wiper mechanism is asked to move too far from its original limits of travel, it can hang up, even if it is well lubricated.
Wiper motor coming out . . .
Wiper mechanism removed . . .
All these fittings had a lot of resistance in them before lubrication . . .
Pretty ugly, but now that it's lubricated and back in place, it's working fine . . .
TaDa! Working wipers!
Thanks!
DDs:
Projects: 86 Ram50
Re: Wiper realignment - how do I fix it? [Re: 87_Montero] #989768 03/17/10 01:54 AM
K_Raider Offline
Just the man Im looking for. <img src="/forums/images/graemlins/smile.gif" alt="" /> Did you put the assembly back in as 1 piece? Did you have much trouble if you did? My linkages fell off and I'll be diving into it this weekend. Thanks for the pics too. <img src="/forums/images/graemlins/kewl.gif" alt="" />
88 Raider- sitting on a full size Chevy frame with 35.5x11.50x16 Dyna Torque II tractors
89 Montero- stock 2.6 M/T 30-9.50 BFG all terrains on American Racing Wheels
99 2500 Ram- 285-75-16 Uniroyal all terrains,straight pipes with no cat (yes its loud)
PHP: 7.4.33 Page Time: 0.012s Queries: 15 (0.009s) Memory: 0.6183 MB (Peak: 0.7142 MB) Data Comp: Off Server Time: 2026-11-02 21:50:40 UTC
