SR5 instrument cluster #989886 03/14/10 03:11 PM
P
pugski1043 Offline OP
My 88 4Runner has the basic instrument cluster, I was thinking of getting an SR5 cluster and swapping it in. Is there anything I should know before buying one? Does it need to be from a 4 cylinder? (what I have) or will one from a 6 cylinder work ok? What years are compatible? I would assume 87-89. Any advice is appreciated.
Jim
1994 Toyota Pickup 22RE, EB 268 cam , 2.25 LCE exhaust.
1988 Toyota 4Runner, mostly stock but hopefully not for long
Re: SR5 instrument cluster [Re: pugski1043] #989887 03/14/10 07:11 PM
stock87 Offline
Anything from 85-88 in the truck and 85-89 in the 4Runners should work. You need to match engines (4cyl vs. V6), and manual vs. auto, but otherwise it's pretty much plug and play.
http://humboldt.edu/~pke1/Truck/index.html
My Truck: 1987 XtraCab DLX 22R 4WD 5 Speed Manual
"Speed has never killed anyone. Suddenly becoming stationary, that's what gets you." -Jeremy Clarkson
Re: SR5 instrument cluster [Re: stock87] #989888 03/14/10 09:04 PM
G
Greg_Canada Offline
You also need an oil pressure sensor from an SR5 truck.
89 4Runner
Re: SR5 instrument cluster [Re: Greg_Canada] #989889 03/14/10 10:13 PM
RatLabGuy Offline
As mentioned, teh key is matching motors and transmissions, the pinning is different for a/t vs manual (learned teh hard way).
Technically 4 vs 6 cyl works, but the RPM readings will be off by 50%.
Question Reality.
Re: SR5 instrument cluster [Re: RatLabGuy] #989890 03/17/10 02:31 AM
redman Offline
As mentioned, you are going to want to match size of your motor to the doners motor.
Although, I have had the SR5 cluster in mine now and it came out of an automatic. Pluged right up. Of corse my fuel guage doesnt work but it didnt work with the original cluster. I believe its just my sending unit, which from what I hear, needs to be replaced with a SR5 sending unit in order to have the low fuel light...
BTW, I have a '87 4cyl 4x4 5sp and used an '85 4cyl 2wd Auto
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.6038 MB (Peak: 0.6681 MB) Data Comp: Off Server Time: 2026-06-22 23:04:50 UTC
