Turn signal trouble
#989941
03/15/10 04:16 PM
Got a wierd electrical problem. My left turn signal doesn't work at all. Not even the dash light works and no clicky sound. Right signal works just fine.
Already replaced the bulbs front and rear. Definitely not the fuse but I replaced that anyway just to try it. Haven't replaced the relay but that controls more that just the signals and it's only the left not working.
Loose wire/connection at the dash itself maybe? It's been too cold for me to really dig around yet but hoping someone can steer me in the right direction for when it warms up.
Desha '94 Amigo XS 4WD 33" Cooper STT's, 2.5" lift w/OME springs, Shackles, DOR UBSkidderz & Balljoint reversal,Calmini header, custom Boulder Bars Jacobs Ultra Team Off Road Ignition
Re: Turn signal trouble
[Re: HunterD]
#989942
03/16/10 02:20 PM
Hmmm...my first thought is a bad ground at the light fixture, but that can't be it, you would still get a fast flash or constant on, not nothing...
Steve Carlson - 95 Trooper LS expo rig Serenity now!
[Re: HunterD]
#989943
03/16/10 07:38 PM
Possibly a wire from the switch to the lamp. Most likely the switch since both the signal and signal indicator malfunction.
[Re: HunterD]
#989944
03/22/10 07:07 AM
Have you changed the stalk signal unit itself? ![[Linked Image]](http://i232.photobucket.com/albums/ee60/Egelwolf/Allerlei/FlasherUnit.jpg)
'99 Isuzu Frontier (Rodeo) Intercooled 280DT LX
[Re: Egelwolf]
#989945
03/30/10 11:30 PM
Had the same problem. Ended up having to replace the whole turn signal mechanism/harness.
Some say you can clean the contacts - went down that road - no luck.
If you have to do this - I wrote up a how-to that's in the Isuzu archives at this site.
Mike Murrell '95 Rodeo - 3.2 liter - 2WD - Automatic '04 Tacoma - 4 banger - Automatic
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.006s) Memory: 0.6081 MB (Peak: 0.6723 MB) Data Comp: Off Server Time: 2026-10-24 08:16:36 UTCValid HTML 5 and Valid CSS
