Gen1 heater hoses
#990445
03/19/10 03:12 AM
Does anyone know of a good way to change the heater hoses on a 2.6L gen1 montero. It seams like there is a collector behind the engine on the drivers side. I cant see it very well I have a burst hose somewhere i can see it but i see liquid. thanks guys
84' Montero 2.6L SWB
Re: Gen1 heater hoses
[Re: RigilKent]
#990446
03/19/10 04:15 AM
When i did my body lift one of the hoses busted, i used a combination of a small screwdriver and a small ratchet. It's easier to access the hoses when you remove the carburetor housing and patience. I got the hoses from autozone and took them what i had for them to match.
1987 Dodge Raider, stick on 33", 2.5" BL, Con-ferr roof rack, Hella driving lights & pencil beam lights.
Stuff collecting dust in the garage SR Axle LSD 3rd member Early Gen 1 Bouncy seat Early Gen 1 two piece rear bumper 2 sets of SWB Gen I rear seat-belts. Set of Aisin Hubs.
[Re: NickR]
#990447
03/19/10 04:48 AM
Wash your hands in very hot water to shrink them and toughen the skin. This will let you get your hands in there far enough to cut them really good, and the toughened skin on your shrunk hands will tear really impressively. I know some really good curses to put on the guy who used the screw clamp and put the thing on so you can't get at the screw head, too, and some more for the one who used the spring clamps that you can't get pliers on to squeeze them open...
[Re: fasteddy]
#990448
03/19/10 04:56 AM
I know some really good curses to put on the guy who used the screw clamp and put the thing on so you can't get at the screw head, too, and some more for the one who used the spring clamps that you can't get pliers on to squeeze them open... Which I could help but maybe this guy can... ![[Linked Image]](http://inlinethumb45.webshots.com/36716/2472793260104986527S600x600Q85.jpg) <img src="/forums/images/graemlins/wink.gif" alt="" />
[Re: off-roader]
#990449
03/19/10 05:34 PM
yeah that's what i figured. unfortunately i have very large hands. So basically its a [censored]. I wish the heater lines were where the AC lines went in. much easier. thanks guys
[Re: RigilKent]
#990450
03/19/10 07:42 PM
When I replaced the heater hoses on my Raider, I required stitches; I was hung up on one of those springy hose clamps and ripped my glove. The hose that connects on the rear of the carb shredded my arm, some scarring still. <img src="/forums/images/graemlins/zombie.gif" alt="" />
[Re: rxinhed]
#990451
03/19/10 08:36 PM
I suggest pulling the engine as an easier and safer alternative.
Also, if you have a Mikuni carb, don't neglect to check/replace the small coolant line that runs to its base.
[Re: RigilKent]
#990452
03/20/10 12:27 PM
The hose that fails most often is the one on top of the intake, that one is not a horror to work on. If you need to change the one from the bottom of the intake to the tube around the back of the engine or the heater returnI would suggest disconnecting a battery cable. You will be working right above the starter and if you get a tool into the battery cable you will be even less happy that when you started.
And Eddy, That was funny <img src="/forums/images/graemlins/lol.gif" alt="" />
[Re: OldColt]
#990453
03/20/10 03:50 PM
Especially on a 5 speed that's in gear....
[Re: hazy_daze]
#990454
03/20/10 07:20 PM
the one on the top of the mani sees the most heat. Mine always blew in the first curve. And I've done my share of battery tool welding....
