My new t-case skid plate #990518 03/20/10 02:16 AM
SandRaider Offline OP
While waiting to find some manual hubs, I decided to fix my stock t-case skid plate and ended up building a new one. My old one was pretty thrashed as you can see.
Eric
89 Raider V6, 35s, 5sp, welded rear, 8k winch
89 Raider 2.6 going on 84 4runner frame
Re: My new t-case skid plate [Re: SandRaider] #990519 03/20/10 02:40 AM
Mad_Scientist Offline
<img src="/forums/images/graemlins/kewl.gif" alt="" /> Looks stout. Could may be use a couple more gussets. <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: My new t-case skid plate [Re: Mad_Scientist] #990520 03/20/10 03:28 AM
Looks good overall. I've thought about what to make if I ever really wheel enough to thrash the stock one. <img src="/forums/images/graemlins/rolleyes.gif" alt="" /> I have thought something similar to yours, and also with some sides to box it up, and then a drain hole or two for when it splashed up. I would also maybe "top coat" it with undercoating.
Re: My new t-case skid plate [Re: MontyMcV] #990521 03/20/10 03:52 AM
It's made from 3/16" steel and I added gussets on the on the rear part. I tried to just remake the stock one so I could use the stock bolts/holes, while trying to improve it. It is thicker, has a better approach angle and has about 1/2" extra ground clearance. I didn't spend alot of time on this and I don't really care if it looks pretty, as long as it does it job.
Eric
Re: My new t-case skid plate [Re: SandRaider] #990522 03/20/10 04:44 AM
G
Guns_and_Roses Offline
make me one that is a little better quality on the looks.....
and i will pay you for your time and to ship it to me in Cali.
mine is dented and bent and the replacement i made bites.
smile
Re: My new t-case skid plate [Re: Guns_and_Roses] #990523 03/20/10 03:46 PM
Tag Offline
You must have never touched it on a thing. Mine you could bend by stepping on maybe even by hand. My replacement may not have as good of clearnce as the stock one but I can do bigger stuff because I can bang on it without as much fear.
89 2dr 3.0 AT, manual hubs. 33x12.5 MT
gen 2 coils,Cranked front tbars
Dons rocker protection, Front/Rear Bumpers. ARB rear locker, 2" BL, Beefed up skid plates/trailing arms. Gen II uca, 2 Bouncy seats www.youtube.com/TagGeorge
Re: My new t-case skid plate [Re: Tag] #990524 03/20/10 05:13 PM
G
maybe i have changed my mind and i now want Tag's set up!
smile
Re: My new t-case skid plate [Re: Tag] #990525 03/20/10 05:29 PM
justice Offline
Here's mine. Since at this point my stock skid on my 89 was a virgin so it was in good shape I re-enforced it. I used leftover stock from another project and it was not quite the right size to get complete coverage, but its way better than stock. One thing I noticed is that the auto T-Case skid is different from the Manual.
Re: My new t-case skid plate [Re: justice] #990526 03/22/10 03:11 AM
hazy_daze Offline
Heh. Heh. He said VIRGIN!!!
Good stuff Justice! Glad you're home safe <img src="/forums/images/graemlins/kewl.gif" alt="" /> Thanks for your service <img src="/forums/images/graemlins/patriot.gif" alt="" />
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6325 MB (Peak: 0.7375 MB) Data Comp: Off Server Time: 2026-06-07 04:48:24 UTC
