Important Q's Regarding Headgasket Change on 22RE #991089 03/23/10 04:14 PM
P
pdonahue Offline OP
Hi guys, I'm doing a head gasket change on my '85 4Runner with the 22RE and I have a few questions. All responses are greatly appreciated.
1. Can I reuse the head bolts?
2. Do the head bolts need to be re-torqued after the initial torque?
3. Should the bolt holes in the block be completely dry and oil-free?
4. Should the bolts themselves be completely dry and oil free? My friend who's helping me says he's done many head gasket changes (not on toyotas) and says the bolts get oiled before you screw them in and torque them?
5. How likely is it that the block itself could be warped? About 5000-10,000 miles ago I overheated the engine and warped the old head. A new one was put on, and the head gasket failed after about 5-10,000 miles.
Any other general tips would be greatly appreciated as well.
One other thing. Could someone post the link to the timing of the engine? I forgot which plug has to be shorted out during timing, its been a while since I did that.
It's hard to beat old trucks!!
Re: Important Q's Regarding Headgasket Change on 22RE [Re: pdonahue] #991090 03/23/10 07:40 PM
mosk Offline
I'll give you my answers, but they are skewed towards the turbo motors, which chew through head gaskets. Some of these may be overkill on a normally aspirated 22RE that's making < 130 rwhp, so keep that in mind.
I wouldn't. I mean, you can, but in general I don't think it's a good idea. Head bolts stretch. Even though the 22RE head bolts aren't torque-to-yield, I would not reuse them, especially if they were the original set.
If you just replaced them at your last rebuild, that's different. In that case, I'd probably re-use them once.
Yes. I retorque after the first full warm-up/cool-down in the driveway, and again at around 500 miles.
YES! Make sure there is no oil at the bottom of the bolt holes, or you will not be able to properly seat the bolts. Also, there are different torque specs depending on what type of lube is used to assemble the bolts. I only use ARP studs (see below), and they have very different torque ratings depending on if you use their lube or straight 30 weight oil.
Your friend is right. See above.
These blocks have a high nickel content and are really strong.
That being said, while it's much easier to warp the head, it's still possible to warp the block, especially if it's already been overbored. A straight edge and a feeler gauge should tell you what you need to know.
ARP head studs!! Outstanding investment, well worth the $110 or whatever they are going for. Keep in mind that the 22RE has a weak head gasket design; you don't see it fail as often on a 22RE as it does on the turbo 22RTE, but it's still a weak design: :O:O:O:O:. That's 10 bolts for 4 cylinders, which means the inner two cylinders share six bolts between them. This means the bolts do not share their load equally, as the inner ones are subject to more stress and stretch sooner, which causes the head to lift a little, and then -- blammo!-- new head gasket time. So use the best quality components you can afford, be meticulous in your work, follow a "best practices" approach wherever possible, and follow up by retorquing twice when you have it all back together.
My .02 cents,
Jeff
Jeff Moskovitz
1986 turbo 4X4 truck
1998 2.7L/M5 4X4 4Runner
Jeff's 22R-TE page
22RTE Turbo Truck Forum (advertising free)
Re: Important Q's Regarding Headgasket Change on 22RE [Re: mosk] #991091 03/23/10 10:49 PM
P
pdonahue Offline OP
Thank you! That was a very thorough response.
I am confused about 1 thing though, through my research it seems as far as 22RE engines, the head bolts in '85 and '86 are NOT torque-to-yield and from '87-'97 they are.
So I'm wondering what the difference is because most parts stores can't get head bolts for my '85 because replacement is not suggested? Is that the reason?
I"m not really sure what to do at this point, bolt-wise?
Re: Important Q's Regarding Headgasket Change on 22RE [Re: pdonahue] #991092 03/23/10 11:33 PM
missouriman Offline
good advice.
good to see you are still around there Mosk.
any new projects or toys? what have you been up to?
Re: Important Q's Regarding Headgasket Change on 22RE [Re: missouriman] #991093 03/24/10 09:42 AM
mosk Offline
I still lurk on this forum a bit, but between family and work my truck wrenching time isn't what it used to be, lol. A few years ago I started a forum just for the turbo 22RE motors (link in sig), and it's been filling my bench racing needs. Otherwise, I haven't been up to much -- our kids are 9 and 5, which are great ages, so we spend a lot of time with them. Gotta get the good years in now before they turn into surly teens <img src="/forums/images/graemlins/smile.gif" alt="" />
Anyway, thanks for asking. Sorry for the derail, OP -- maybe try a place like headbolts.com, which has head bolts for under $30/set? Or go with the ARP studs, which are $124/set at JEGS.
Jeff
Jeff Moskovitz
Jeff's 22R-TE page
PHP: 7.4.33 Page Time: 0.013s Queries: 15 (0.009s) Memory: 0.6109 MB (Peak: 0.6957 MB) Data Comp: Off Server Time: 2026-11-02 12:29:54 UTC
