Heater core replacemet #991959 03/27/10 05:07 AM
5
5jackz Offline OP
Heater core blew followed by a chewed up drivers side inner and outer bearings. I replaced the bearings and heater core but after attaching up the battery, the airbag light flashes. Yes, I did connect the harness back up. Any hints? <img src="/forums/images/graemlins/scared.gif" alt="" /> I also have a P0440 CEL code and have changed the gas cap. I will be cleaning the throttle body next weekend as well as changing the PCV valve. I did notice that after cleaning the present PCV valve I temporarily get less blow back ( intermittent/plugged pcv ) Any thoughts?
2000 with Eibach Suspension lift,Warn man. hubs,K&N air filter,15x8 mags with 31's, 3.75" body lift.
Re: Heater core replacemet [Re: 5jackz] #991960 03/27/10 09:59 AM
Axe Man Offline
Kia Moderator Emeritus
You must have disconnected an airbag before the electrical system was totally discharged or before the battery was disconnected. In order to prevent the airbag diagnostic unit from setting a check light the following must be done before disconnecting any airbag wiring:
1. Disconnect the battery.
2. Turn on the headlights.
3. Wait approx 15 minutes.
If this procedure wasn't followed the airbag system will indicate a fault. The only way to reset the system is with a Kia Pro Scan Tool. And only Kia Dealers have this tool so unfortunately you must visit a dealer and have the system reset. And expect to be charged a diagnostic fee.
If a new gas cap didn't fix the P0440 code then inspect all the vacuum lines going to the vapor canister unit.
1998 Sportage - Gone.
2004 Honda Civic Coupe.
2007 Suzuki Grand Vitara - She got it.
Re: Heater core replacemet [Re: Axe Man] #991961 04/08/10 07:25 AM
5
5jackz Offline OP
Replaced the PCV valve and cleaned the throttle body. I did find one hose to the vapor canister that wasn't on tight. Is the vapor can. supposed to sound like sand, and is there a purge filter that should be replaced on it?
PHP: 7.4.33 Page Time: 0.005s Queries: 15 (0.003s) Memory: 0.5930 MB (Peak: 0.6468 MB) Data Comp: Off Server Time: 2026-05-25 14:42:28 UTC
