Help!!!...T-100...Dead in the driveway... #992010 03/28/10 03:43 PM
Kapuna Offline OP
1995 T-100... 3.4L... 187K miles...
Best truck I've ever owned...
However, she's dead in the driveway....
Drove home from work Wednesday night and parked...
Had a bad storm on Thursday, so didn't drive the truck...
Friday morning... Dead...
Plenty of battery....turns over with gusto...
Wouldn't even try to start...
No check engine light....
Tried to listen for fuel pump...can't hear it...
But understand that would be normal???.. (no sound from fuel pump)
Checked for fire by pulling a spark plug...
Can't seem to see any spark at all....
So...what next...
Hate to just tow it to a garage without trying something...
Any help is greatly appreciated...
Re: Help!!!...T-100...Dead in the driveway... [Re: Kapuna] #992011 03/28/10 08:07 PM
ErikB Offline
Toyota Moderator
Sounds like you're on the right track checking for spark and fuel (although you still don't know if you're getting fuel).
I'd probably crack a fuel line open to see if you're getting fuel, and then probably just start digging into the service manual troubleshooting procedures:
http://www.ncttora.com/fsm/1996/SIL/tech...eg5vzfe/pst.pdf
http://www.ncttora.com/fsm/1996/SIL/fsm/repair.html
That is for a 4runner, but it should be the same. There is also a T100 manual on that site. Its just one huge file instead of broken up.
http://home.4x4wire.com/erik
Re: Help!!!...T-100...Dead in the driveway... [Re: Kapuna] #992012 03/28/10 10:39 PM
BamZipPow Offline
Check yer grounds...especially the one going to the air plenum and the one going to the left fender by the battery. When you checked fer spark, how did you do it? Did you test it to engine block, the fender or to the negative post on the battery?
I know this might sound stoopid...but do you have gas in the tank? Are there any leaks in there that could let water in? Have you tested the fuel pump?
When you cranked the engine...how long did you crank it fer? More than 10 seconds? If so, pull one of the plugs and see if it's wet with fuel.
Did you check yer fuses? Did you check the fusible links? (AM1 40A, AM2 30A, Alt 80A). Fuses (EFI 15A, IGN 7.5A)
Re: Help!!!...T-100...Dead in the driveway... [Re: BamZipPow] #992013 03/29/10 04:30 AM
CJMT100 Offline
Stupid question, but did you hold down the gas when you were trying to start it over? I am not sure the exact reasons it work, but Ive done it multiple times to many cars..
Re: Help!!!...T-100...Dead in the driveway... [Re: Kapuna] #992014 03/29/10 07:39 PM
Kapuna Offline OP
She's up and running now... <img src="/forums/images/graemlins/smile.gif" alt="" />
It was a 7.5 amp fuse in the inside fuse panel.
When I bought the truck, the inside fuse panel cover was missing, so there's no diagram saying what is what.
And couldn't find the right info in my Chilton book. <img src="/forums/images/graemlins/confused.gif" alt="" />
Therefore, it took longer than expected to find the problem.
The panel cover is now on order at the dealership.
Thanks for all the help, guys...
I love my 'lil T-100.... <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: Help!!!...T-100...Dead in the driveway... [Re: ErikB] #992015 03/30/10 02:57 AM
RadiOwATt1oo Offline
How about your catalytic cconverter, do you still have it?
Re: Help!!!...T-100...Dead in the driveway... [Re: Kapuna] #992016 03/30/10 08:50 AM
kewlynx Offline
Bet it was the ignition fuse; let us know when your panel shows up <img src="/forums/images/graemlins/wink.gif" alt="" />
**ubi apis- ibi salus**
Re: Help!!!...T-100...Dead in the driveway... [Re: kewlynx] #992017 03/30/10 08:37 PM
ErikB Offline
Toyota Moderator
Glad you figured it out. You might still have to buy the sticker for the fuse panel that has the labels on it...
Re: Help!!!...T-100...Dead in the driveway... [Re: ErikB] #992018 03/30/10 08:46 PM
BamZipPow Offline
Re: Help!!!...T-100...Dead in the driveway... [Re: RadiOwATt1oo] #992019 03/31/10 03:04 AM
Brew Offline
So what was causing your 15A fuse to blow? Just as pertinent as asking about the catlytic converter. <img src="/forums/images/graemlins/nana.gif" alt="" />
98 T100 SR5 4x4 3.4L auto, TRD Goodies, Bilsteins, engine/TC skids, 2" body/d.train lifts, F/R ARBs, 4.56 R&Ps, Aisin hubs, 255/85R16 Dunlop Rover RVXTs (street), 16x7 +8mm offset wheels, custom bumpers, Warn M8000, Master-pull synth. line
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.004s) Memory: 0.6410 MB (Peak: 0.7615 MB) Data Comp: Off Server Time: 2026-05-29 16:41:24 UTC
