Vacuum Line Repair/Replacement #992071 03/29/10 01:24 AM
Jim_Paget Offline OP
The vacuum line which feeds the heater controls under the dash in broken where it goes through the firewall. Is it possible to get to it without removing the A/C unit and/or the heater core?
(This is on a '91 Trooper).
Jim Paget
88 YJ with a few changes
www.rrr4x4.com
Re: Vacuum Line Repair/Replacement [Re: Jim_Paget] #992072 03/30/10 08:53 PM
Craig Offline
I think you can access it by removing the glove compartment box.
Buy a Trooper. You'll be glad you did.
Re: Vacuum Line Repair/Replacement [Re: Jim_Paget] #992073 03/30/10 10:53 PM
bamashooter Offline
Where it "goes through the firewall" should be a double nippled fitting. The line under the hood attaches to one end and the line in the cabin attaches to the other end. That's how it is on my 89 anyhow.
Re: Vacuum Line Repair/Replacement [Re: bamashooter] #992074 04/06/10 04:07 AM
Well, a couple of good suggestions, but neither panned out. The line runs (ran) through the same hole as the air conditioner pressure side line rather than using a bulkhead fitting. On the inside, I pulled the glove box, but the fitting comes into the cab behind the a/c unit.
I am going wheeling this weekend, so I am not going to worry about it for now.
Jim Paget
www.rrr4x4.com
PHP: 7.4.33 Page Time: 0.009s Queries: 15 (0.006s) Memory: 0.6010 MB (Peak: 0.6563 MB) Data Comp: Off Server Time: 2026-10-21 20:44:59 UTC
