Fuel Pressure #992323 03/31/10 09:25 PM
kmattinson Offline OP
I have the 3.4 v6 in my 90 trooper and have finally put the bigger throttle body on it. I had the bigger injectors in my old 2.8 throttle body, but the bigger body with the injectors definitely performs a lot better and gets better gas mileage. I set the TPS at .5v and idle is at around 700 right now, but it still occasionally dies on me when I go in reverse or am at a stop light.
So I think the fuel pressure is the culprit. Now my question is how do I adjust this? I still haven't put a fuel pressure gauge on it, but will as soon as I have time away from school. I know you can play with the spring, and the spring I am using is new from a rebuild kit. So what is the best way to adjust the fuel pressure if there is a different way then stretching the spring?
Thanks
Re: Fuel Pressure [Re: kmattinson] #992324 04/01/10 01:19 AM
Ed Mc Offline
'90 Troop 3.4 LS
'89 Troop RS (Has Valve Issues, needs Counseling)
HI, I'm Ed and I'm a Trooper-holic!
Keep On Troopin'......
Re: Fuel Pressure [Re: Ed Mc] #992325 04/01/10 10:01 PM
sweet thanks Ed. I still can't tell what the best way to test the fuel pressure is on my trooper. What do you guys do to get a fuel pressure gauge on there?
Thanks,
Kyle
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.5939 MB (Peak: 0.6479 MB) Data Comp: Off Server Time: 2026-06-21 19:05:17 UTC
