I did a 3 pt turn and REEEEEK from the front end #992355 04/01/10 03:34 AM
Rafterman191 Offline OP
Seemed like it was the outside wheel making the noise. I got 31 10.50 15's on stock rims. Is that a normal noise for a hard, slow turn. I am driving the family to Lake Monroe, IN next week and gonna haul about a 14ft pop up trailer. What should my checklist be (I only have tomorrow to do it). Tires are new, I got a decent enough spare. Oil and tranny fluid looked clean enough.
'91 Montero RS
'96 Sidekick JLX
'78 Wifey XXX
let me tell you of the days of high adventure...
Re: I did a 3 pt turn and REEEEEK from the front end [Re: Rafterman191] #992356 04/01/10 04:04 AM
justice Offline
grease your steering stops.
Re: I did a 3 pt turn and REEEEEK from the front end [Re: justice] #992357 04/01/10 04:32 AM
0778drz110 Offline
check your muffler bearings <img src="/forums/images/graemlins/kewl.gif" alt="" />
steering stops grinding, nothin to worry about <img src="/forums/images/graemlins/smile.gif" alt="" />
Re: I did a 3 pt turn and REEEEEK from the front end [Re: Rafterman191] #992358 04/01/10 04:56 AM
W
WagonMaster Offline
Might be a loose power steering belt, that will only squeak at high pressure (like full turn) now, but will get worse over time. Just test belt deflection, then spray some WD-40 on the belt. That will give it extra grip. If the squeaking stops, tighten the belt.
HUMMER .25: No need to compensate.
1989 Dodge Raider: 3.0/5
1992 Chrysler LeBaron Convertible: 3.0/A
1994 GMC Safari: 4.3/A
Re: I did a 3 pt turn and REEEEEK from the front end [Re: WagonMaster] #992359 04/01/10 05:10 AM
PHIL_ Offline
Re: I did a 3 pt turn and REEEEEK from the front end [Re: PHIL_] #992360 04/01/10 06:38 AM
'91 Montero RS
'96 Sidekick JLX
'78 Wifey XXX
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6128 MB (Peak: 0.6830 MB) Data Comp: Off Server Time: 2026-06-07 05:43:58 UTC
