Trans mount? #992372 04/01/10 06:29 PM
StockRaider Offline OP
I found the source of my vibration at higher speeds, seems the rubber on my transmission mount is nearly all deteriorated. I can't seem to find a part# for the 89-91 Gen1 V6 Montero. I was wondering if anyone went through this problem before and sourced the replacement mount? Or if anyone knows how I could replace the rubber itself?
Richard E
1989 Montero - Stock-ish
1983 Honda XL600R
Re: Trans mount? [Re: StockRaider] #992373 04/02/10 01:55 AM
P
pcc Offline
RockAuto?
Re: Trans mount? [Re: pcc] #992374 04/02/10 02:04 AM
Temple Offline
the bushing/mount the goes on the bottom side of the trans, is no longer carried or reproduced, as of last year when i was in cali, and had a trans seal replaced the shop noticed mine was shot also, and said they couldnt find one in mitsu/ or aftermarket and that theyd have to get a bushing guy to make one. i say get some body mounts cut them to fit and thoughs will be your new trans mount might help with the shaking but you'll get a little more feedback from the drivetrain. <img src="/forums/images/graemlins/kewl.gif" alt="" />
"No obstacle brute force and ignorance cant overcome"
89 SWB RAIDER (IN PIECES)
06 F250 SuperDuty Axles
Currently saving for F-O-A 18" Coilovers
Cummins 6bta/5r110w/np271
Re: Trans mount? [Re: Temple] #992375 04/02/10 02:53 AM
They still make them for the 2.6 Gen1, and all 3.0s after 92. But they are all too different to make work. <img src="/forums/images/graemlins/frown.gif" alt="" />
Richard E
1983 Honda XL600R
Re: Trans mount? [Re: StockRaider] #992376 04/02/10 03:56 AM
mxmikie Offline
if it is a disc/insert i can prolly do it in poly
Re: Trans mount? [Re: mxmikie] #992377 04/02/10 04:04 AM
Temple Offline
if its like mine its two plates with the bushing atached on the buttom and top (molded) so they have to be cut and clear out my thoughts was putting the polys in there and with some washers and bolts keeping them in place maybe some sweet easy mod work just to make sure nothing rubs.
Re: Trans mount? [Re: Temple] #992378 04/02/10 04:11 AM
If I redo it myself, I will probably try to emulate the OE way of using a high strength adhesive and bushing material. I know some mounts are heat pressed, but still have some sort of a bonding agent. A bolt through the bushings would really do opposite what it was designed to do. Also the center has those 2 loops that keep everything together while allowing the mounting plates to move I think to absorb driveline shock.
Richard E
1983 Honda XL600R
Re: Trans mount? [Re: StockRaider] #992379 04/02/10 03:52 PM
RigilKent Offline
What if you used poly and drilled some small holes through the whole thing then laced it with some small diameter cable. that way it would still move but have that extra strength holding it all together along with the high strength adhesive? just a thought
84' Montero 2.6L SWB
Re: Trans mount? [Re: RigilKent] #992380 04/02/10 04:05 PM
justice Offline
I'm pretty sure you can still get this part, but you will need to do a little digging to find it. Look up the Mitsubishi part number in Caps and then cross reference it in Google.
Re: Trans mount? [Re: justice] #992381 04/02/10 08:51 PM
zarktheshark Offline
I think the asa part# you are looking for is MB581620.
'88 Raider. 2.6L dead...2.4L swap in progress, AT, 33's, 2 bouncy seat,AC, CC, 2.25 exh, 2" Tbar, 2" BL, rear DB, rear LSD,4.90's, SW hubs,gen2 uca's, KYB shocks, snorkel, elec fan, MSD.
'99 chev k3500 crewcab
'15 Subaru XV
'03 BMW i325
PHP: 7.4.33 Page Time: 0.008s Queries: 16 (0.005s) Memory: 0.6385 MB (Peak: 0.7616 MB) Data Comp: Off Server Time: 2026-07-09 16:51:10 UTC
