Page 21 of 23 1 2 19 20 21 22 23
Re: To rebuild or not to rebuild, that is the question... *PICS* Update [Re: hazy_daze] #992711 10/05/10 09:13 PM
DRaider90 Offline
What I had done would've cost the average Joe about $800. I didn't pay that much, though...
On a sidenote, I found some tires.
No reason now not to go to Uwharrie! <img src="/forums/images/graemlins/drunk.gif" alt="" />
88 Raider(Red):160k-Reman'd 2.6-5spd-Weber-SW Hubs-34x9.5 TSL-OffRd Pkg-1"Tbar-2"BL-CB
88 Raider(Silver):No 2.6/Bad KM145 Parts/Project
88 Montero(Brown):No 2.6,4.88s Parts/Project
[b]4X4 STICKERS,SHIRTS,ETC:
4WD Stickers AT COST.[b]
Re: To rebuild or not to rebuild, that is the question... *PICS* Update [Re: DRaider90] #992712 10/05/10 09:47 PM
hazy_daze Offline OP
Except for that pesky work thing...
Re: To rebuild or not to rebuild, that is the question... *PICS* Update [Re: hazy_daze] #992713 10/06/10 04:23 AM
Oyaji_Jon Offline
C'mon, Larry, you've got to give us more than that... <img src="/forums/images/graemlins/lol.gif" alt="" />
73
-Jon
KJ6GVM
As seen on Expedition with TX plates: VEGETARIAN - An old Indian word for poor hunter
Grampa's Trooper
1974 FJ40
1987 FJ60
Re: To rebuild or not to rebuild, that is the question... *PICS* Update [Re: Oyaji_Jon] #992714 10/07/10 04:28 AM
35x12.50-15 BFG KM2's on 15x8 Black Rock D-hole steels in Teflon matte black. I should be driving it by the 18th.
I hope to have all the little it-picky stuff ironed out by then. I was planning a dual battery setup with both batteries in the rear. But, Frank has kinda talked me out of it. Almost...
Re: To rebuild or not to rebuild, that is the question... *PICS* Update [Re: hazy_daze] #992715 10/09/10 04:32 AM
E
eowen Offline
5k-6k,, yeah thats alot of work,,
since i last posted
it has gotten colder here in TN, more so at night and at the crack of dawn. when i leave for work
drove 26miles to work in my montero
got there no problem. "last week i did some math" i get 11 mpg....... that cant be normaly
anyways during lunch,, i went out to my montero and it was like someone got murdered. oil all over the place,, ground, tran' as far back as the rear axle......
so this weekend im going to pull the motor.
first question.. "of many im sure"
will a 6g72 dohc 24v bolt to that tranny, its the same as yours
no one can answer that question,, no one,,
the way i look at it, its a 6g72 block, just difrent heads. why wouldnt it bolt up? you know
i dont care about the other stuff i just want to know if it will bolt up.
if i cant find one thats in good shape im rebuilding the d!@$$ thing
so the 18th you say.. good luck post more pictures haha
whats this do? "boom"
Re: To rebuild or not to rebuild, that is the question... *PICS* Update [Re: hazy_daze] #992716 10/09/10 05:15 AM
Oyaji_Jon Offline
This sounds <img src="/forums/images/graemlins/kewl.gif" alt="" /> ! I can't wait to see it.
73
-Jon
KJ6GVM
Grampa's Trooper
1974 FJ40
1987 FJ60
Re: To rebuild or not to rebuild, that is the question... *PICS* Update [Re: eowen] #992717 10/09/10 05:31 AM
justice Offline
since i last posted
You would probably get more info if you started a thread specific to your question, but the answer is yes, the DOHC block will both to the montero tranny. The rest, such as engine management (ECU etc) and exhaust, you'll have to figure out on your own...
Re: To rebuild or not to rebuild, that is the question... *PICS* Update [Re: justice] #992718 10/20/10 12:32 AM
Drove it to and from work today. Uneventful. Only issues to sort are:
No O/D.
Autometer Water & Trans Temp gauges aren't registering.
Needs an alignment after installing the GenII box.
Weld on the aux trans cooler bracket so it can be mounted.
Figure out why, when I ground the base timing plug, it arcs. It's already melted one of my test leads... Ungrounded it's running at 18-20* BTDC at idle.
Then, there's a heap of interior stuff to do in the coming months...
More pics forthcoming...
Re: To rebuild or not to rebuild, that is the question... *PICS* Update [Re: hazy_daze] #992719 10/20/10 01:27 AM
<img src="/forums/images/graemlins/evil.gif" alt="" />Scratch that. Now I have no headlights, I'm blowing fuses in the aux fuse panel like crazy. Got something bad wrong, maybe it's just a pinched wire somewhere... <img src="/forums/images/graemlins/rolleyes.gif" alt="" />
Oh, the joys...
Re: To rebuild or not to rebuild, that is the question... *PICS* Update [Re: hazy_daze] #992720 10/20/10 02:36 AM
After visual inspection and some test light and meter probing, I found 3 blown fuses, 2 burnt thru wires, a bad relay and a fuse panel that was damaged from melting. Replaced the fuses, repaired the wires, replaced the relay and fuse panel and voila. I have headlights back and my Autometer gauges register. I had a couple wires backwards somehow, which had overloaded a few circuits causing the aforementioned damages. I guess all's well that ends well.
Still need to figure out O/D and check if the base timing plug still arcs or not, but I'll save that stuff for tomorrow night...
PHP: 7.4.33 Page Time: 0.016s Queries: 16 (0.013s) Memory: 0.6571 MB (Peak: 0.7841 MB) Data Comp: Off Server Time: 2026-05-29 22:31:00 UTC
