You guys can prolly nail this one on the head.
#992781
04/04/10 03:20 AM
When I go from P to D, my idle drops way down almost enough to kill it. No other problems idling (curb or engaged tranny). It does idle on the low side it seems like. Can't tell you what the tac says off hand. I have read quite a few things that could possibly be causing idle problems, but with the specific symptoms, I figure one of you can narrow it down. <img src="/forums/images/graemlins/kewl.gif" alt="" />
'91 Montero RS '96 Sidekick JLX '78 Wifey XXX
let me tell you of the days of high adventure...
What is "prolly"...
[Re: Rafterman191]
#992782
04/04/10 03:42 AM
Have you turned up the idle screw, just a bit? In drive, your idle should be around 700 - 800 rpm.
Re: What is "prolly"...
[Re: rxinhed]
#992783
04/04/10 04:51 AM
You don't have the AC button in - or switched into the Defrost mode do you?
3=(PI.98 SWB 2.8TD-TH92.LWB 2.8TD)Red90 SWB.V6/bal,forged pistons,bore/95SR lkr&spr/2 bouncies/(ARB.w/Gorilla 12K winch/new stg gear/stg&sus/CJ side mirr/cust tow rec/01 SR wh w/Mich 265-70-16LTX/Rancho5000's/Candy Apple/rock crawlers/Hellas/KC's
[Re: Pete_D]
#992784
04/04/10 05:40 AM
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6033 MB (Peak: 0.6588 MB) Data Comp: Off Server Time: 2026-06-10 07:28:13 UTCValid HTML 5 and Valid CSS
