warning lights, shutoff #992785 04/04/10 03:52 AM
toyT100 Offline OP
I was driving today and had an unexpected shutoff. Was driving about 35-40ish and accelerated into overdrive. (Was probably in overdrive for approx 5sec. give or take) I then had to take my foot off the gas. Upon doing so, and while slowing down, my steering locked up and I realized my A/T oil temp and also my battery light came on, and that my truck had completely shut off while rolling. Shifted into neutral and started it back up no prob. Any ideas as to what the cause of the shutoff may have been? Thanks for the help!
Re: warning lights, shutoff [Re: toyT100] #992786 04/04/10 04:56 AM
ErikB Offline
Toyota Moderator
Hard to say, but the first thing I'd be doing would be checking and cleaning battery connections and the several ground connections.
http://home.4x4wire.com/erik
Re: warning lights, shutoff [Re: ErikB] #992787 04/04/10 04:45 PM
CJMT100 Offline
Bad connection, possibly bad alternator.
Clean all connections, use a multimeter to check battery (12-12.5V) and alt (at least 13.5-14.5v). And let us know.
Re: warning lights, shutoff [Re: toyT100] #992788 04/04/10 05:23 PM
BamZipPow Offline
I'm with ErikB...start checking all yer grounds out fer contact/cleanliness. <img src="/forums/images/graemlins/wink.gif" alt="" />
Re: warning lights, shutoff [Re: BamZipPow] #992789 04/09/10 10:41 PM
toyT100 Offline OP
It was weird the way it happened. I suspect I have some trans damage possibly and it felt like that was the source of problem. Which still doesnt leave me and better off haha
Re: warning lights, shutoff [Re: toyT100] #992790 04/09/10 11:46 PM
BamZipPow Offline
Just as a side note...when was the last time you drained/replaced yer trans fluid? How's the fluid looking? Do you have an auxiliary trans cooler on there?
Re: warning lights, shutoff [Re: BamZipPow] #992791 04/16/10 10:44 PM
toyT100 Offline OP
changed teh trans fluid at about 200k miles. Still red and no burnt smell or hint of burning. Do not have an aux trans cooler; dint think there was really an applicable necessity for it.
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.6150 MB (Peak: 0.6887 MB) Data Comp: Off Server Time: 2026-10-26 04:14:05 UTC
