'96 Cherokee fuel pressure issues #993372 04/10/10 07:45 PM
Madcat Offline OP
My friend has a '96 Cherokee 4.0L Auto with no fuel getting to the engine. I have replaced the filter, motor, and FPR. Is there some line I'm missing to get the vacuum reference for the FPR? Or am I missing something?
Jim
1979 Pontiac Trans-Am - looking 4 a pontiac 455cid
1988 Trooper II - AMC head, .030 overbore, Calmini cam. Toga HV oil pump, Aisins, soon 2 b turbo
1989 Impulse Turbo - Fidanza flywheel, 270cc injectors, turbo-back exhaust, KYBs F/R
Re: '96 Cherokee fuel pressure issues [Re: Madcat] #993373 04/12/10 08:29 PM
BigJim Offline
It seems to be a problem with Jeeps in general that the grounding systems go away. I had one wrangler that the fuel pump wouldn't work.. I traced (with some help here) it back to a ground that was on the parking brake bracket..
There is also at least one small switch, usually on the fender wells, that must be in working order.
Re: '96 Cherokee fuel pressure issues [Re: BigJim] #993374 04/12/10 09:15 PM
4x4Wire Offline
If the fuel pump relay is working, check the pump.
That solved my no fuel delivery problem.
If the fuel pump relay is not working, there is high probability of a ground issue somewhere...
John Stewart
Editor - 4x4Wire.com
Editor - 4x4Voice
Editor - MUIRNet-News
Re: '96 Cherokee fuel pressure issues [Re: 4x4Wire] #993375 04/16/10 03:37 AM
Madcat Offline OP
Swapped in another pump and its running again.
Thanks for the tips,
Jim
PHP: 7.4.33 Page Time: 0.009s Queries: 15 (0.007s) Memory: 0.6034 MB (Peak: 0.6590 MB) Data Comp: Off Server Time: 2026-11-02 21:48:27 UTC
