Oil Leak? #993473 04/11/10 09:17 AM
Angrybooger2 Offline OP
So it seems the engine i bought had an oil leak coming from underneath the intake manifold.
there is this area with two bolts holding on a plate like thing(sorry for the bad description)that isn't on the engine that was in the raider.
that seems to be where the leak is coming from.
the "new" engine was from a 86 or 87 d-50.
is there like a gasket that could be leaking oil there or something?
88 Dodge Raider
1.5" lift
32"X11.5" A/T tires
15X10 vintage enkei's
Re: Oil Leak? [Re: Angrybooger2] #993474 04/11/10 03:15 PM
FrankR Offline
Has the fuel pump been changed to an electric replacement? If so, the "plate" may be blocking the hole for the OE mechanical pump.
Frank
Re: Oil Leak? [Re: Angrybooger2] #993475 04/11/10 03:15 PM
Kevin C Offline
Fuel pump gasket or the fuel pump can leak oil. If you dont have a pump on the engine it might be a block off plate.
Re: Oil Leak? [Re: Kevin C] #993476 04/11/10 09:12 PM
the fuel pump seems to be ok and it's regular mechanical pump.
hold on im going to take some pictures.
88 Dodge Raider
1.5" lift
32"X11.5" A/T tires
Re: Oil Leak? [Re: Angrybooger2] #993477 04/11/10 10:10 PM
sorry for the ridiculously bad pictures. the lighting was so bad and my cell phone doesn't
88 Dodge Raider
1.5" lift
32"X11.5" A/T tires
Re: Oil Leak? [Re: Angrybooger2] #993478 04/11/10 10:31 PM
Kevin C Offline
Thats the ballance shaft cover thats leaking.
Re: Oil Leak? [Re: Kevin C] #993479 04/12/10 12:58 AM
OH! <img src="/forums/images/graemlins/kewl.gif" alt="" /> ok thanks, how would i go about fixing it?
88 Dodge Raider
1.5" lift
32"X11.5" A/T tires
PHP: 7.4.33 Page Time: 0.011s Queries: 15 (0.008s) Memory: 0.6150 MB (Peak: 0.6933 MB) Data Comp: Off Server Time: 2026-07-14 08:17:36 UTC
