Page 1 of 3 1 2 3
What sources for Gen I SWB lockers. #993498 04/12/10 05:03 AM
F
fido1 Offline OP
I'm starting to look for lockers for my 87 Montero SWB. Are ARBs' the only thing available? I've searched around on the net to no avail. Where have you guys found them. Thanks in advance.
Re: What sources for Gen I SWB lockers. [Re: fido1] #993499 04/12/10 02:07 PM
ARB for the rear. Nothing for the front. You have to do a V6 front axle swap to get an ARB. There is another one out of OZ that appeeared recently. I think it may have been Detroit-like, can't recall. Search user FrankR as he got one.
You can also do a V6 axle swap and fit an LSD from a Starion/Conquest. Search past threads for this as well.
Another option for the rear is to swap an earlier Montero Sport axle with locker into your SWB. Lastly, you could get a Gen II locker from an SR and fab it up for leafs.
Re: What sources for Gen I SWB lockers. [Re: MontyMcV] #993500 04/12/10 02:51 PM
MI_Mitsu Offline
I've got one available <img src="/forums/images/graemlins/smile.gif" alt="" />
Should have it pulled out this weekend!
~jim
89 Montero LS 3.0L/Auto
90 MightyMax 2.4L/Man
Parted/gone - parts available!
89 Montero LS 3.0L/Auto [Blue/Blue] (2 of 2)
89 Conquest SHP
88 Conquest SHP
87 Dodge Raider 2.6L/Auto
91 Montero RS 3.0L/Auto
Others: 37 Lincoln
Re: What sources for Gen I SWB lockers. [Re: fido1] #993501 04/14/10 12:07 AM
F
fido1 Offline OP
Has anyone just welded the front spider gears? How did that work out?
Re: What sources for Gen I SWB lockers. [Re: fido1] #993502 04/14/10 02:28 AM
0778drz110 Offline
weld up the 7.25" front, its not strong enough to put money into
welded works good, but you need manual hubs
Re: What sources for Gen I SWB lockers. [Re: fido1] #993503 04/14/10 05:04 PM
Don't plan on driving on the road with it. You will not like it at all. On the trail is usable especially in a dirt environment. On rock face it is hard on parts.
Re: What sources for Gen I SWB lockers. [Re: OldColt] #993504 04/14/10 11:35 PM
DRaider90 Offline
How exactly is welding the front up bad on the road? I would like to know more about this. Because to my knowledge in 2wd/with the hubs unlocked the front spider gears would have no effect on-road. I know if you weld the REAR it will chirp and wear out tires faster. But I didn't know that the front also had road issues.....
88 Raider(Red):160k-Reman'd 2.6-5spd-Weber-SW Hubs-34x9.5 TSL-OffRd Pkg-1"Tbar-2"BL-CB
88 Raider(Silver):No 2.6/Bad KM145 Parts/Project
88 Montero(Brown):No 2.6,4.88s Parts/Project
[b]4X4 STICKERS,SHIRTS,ETC:
4WD Stickers AT COST.[b]
Re: What sources for Gen I SWB lockers. [Re: DRaider90] #993505 04/15/10 12:44 AM
Have you driven on the road with a fully locked front end? The handling is worse than horrible. In rain or snow even a tight limited slip is not rear enjoyable experience up front.
Sure when in 2wd there is no issue since the hubs are unlocked then.
Re: What sources for Gen I SWB lockers. [Re: OldColt] #993506 04/15/10 01:26 AM
StockRaider Offline
Tell me about it, my front LSD pulls me all over the trails on the snow. I think I need to dump in some additive.
Also Eli, with manual hubs, your front welded up wont be a problem in 2wd. Although you will probably put unnecessary wear on a truck with auto hubs.
Richard E
1989 Montero - Stock-ish
1983 Honda XL600R
Re: What sources for Gen I SWB lockers. [Re: OldColt] #993507 04/15/10 02:01 AM
Oyaji_Jon Offline
Charlie, I'm going to very carefully disagree with you. I used my locked front end in the heavy snow on MN/ND roads for a week during my trip home at Christmas last year. While it took a little getting used to, I had no problems. In fact, I didn't take the truck out of 4WD again, until I hit dry pavement, after the locker helped me get out of a heavily rutted parking where my front diff was stuck on packed snow. Just my .02 after a very limited experience with it.
73
-Jon
KJ6GVM
As seen on Expedition with TX plates: VEGETARIAN - An old Indian word for poor hunter
Grampa's Trooper
1974 FJ40
1987 FJ60
Page 1 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.008s Queries: 16 (0.005s) Memory: 0.6417 MB (Peak: 0.7660 MB) Data Comp: Off Server Time: 2026-06-07 01:54:46 UTC
