diff gearing options #993650 04/13/10 12:16 AM
F
flyinwall Offline OP
i found this on the net and i thought it might be helpful for us here
this is the site i found it on
http://www.turbomagazine.com/tech/0804_turp_kia_sportage_s2000_garage_tech/final_drive_ratios.html
Vehicle Year/Model Final Drive
'94-'02 Kia Sportage 4x4 (front axle) 4.778:1
'99+ NZ market Kia Sportage 4x4 (front axle) 4.625:1
'94-'97 Miata 4.10
'99+ Miata five-speed (4.10:1 on automatic starting in 2000) 4.30
'87-'88 Mazda 4x4 truck (front axle) and Kia NZ Sportage optional 4.44
Mazda RX-8 4.44
'79-'85 12a RX-7 and ('99+ six-speed Miata) 3.909
'79-'82 RWD 626 five-speed ('01+ Australian six-speed) 3.636:1
Kia Sportage aftermarket gears are available 4.875:1, 5.125:1, 5.38:1
Re: diff gearing options [Re: flyinwall] #993651 04/13/10 02:32 AM
DEFBOY35 Offline
the problem is trying to actually get ahold of any of the so called sportage aftermarket gears!
2000 SPORTY, DEF BOY customs, mmm....lockers, mmm... gears, mmm... double transfer case, mmm... stroker
http://www.cardomain.com/ride/2377991
Re: diff gearing options [Re: DEFBOY35] #993652 04/13/10 02:43 AM
Everet Offline
True on trying to get the aftermarket gears.
This article is good for reference on gearing, it is dated and the only place I've heard for gears is out of KOREA. Don't know if the place is still in business.
However, LSD's for those units listed other than Sportage may work in the front of a Sporty.
Maybe someone will have better luck getting info on the gears. Wouldn't mind a set of lower gears.
Re: diff gearing options [Re: Everet] #993653 04/23/10 04:59 AM
DennisThompson Offline
I pulled the front and rear dif out of a wrecked Sportage the other day (1/2 price Wednesdays), I'm going to install my LSD in the rear so when I'm ready to put it in the Kia it will be a 1/2 hour job. If I can't find a good affordable LSD for the front I might Miller (Lincon) lock my original dif and leave the other one open. I can change out the 3rd member before I plan a wheelin trip. Most of the LSDs that come out of the RX7, Miata and S2000 need a lot of wheel speed to lock up and will not lock up with a tire off the ground so do your research before any of you buy one.
Dennis
Re: diff gearing options [Re: DennisThompson] #993654 04/23/10 08:53 AM
DamKia Offline
Kia Moderator
Dennis
Depends on the type of LSD.
Clutch types may well need an extra shim or two fitted to the pack to increase the preload. (normally RX-7's). (This is also done routinely with Toyota and Nissan diffs out here for the same reason)
Torsen (S2000/Miata) will lock at low speeds with only a light application of the brakes ("driving through the brakes")
Re: diff gearing options [Re: DamKia] #993655 04/24/10 08:42 PM
Thats why I said to do your research before you buy one, so you don't get the wrong type. The Ford Ranger FX4 level II used a torsen LSD but I'm sure if it's the same as the Miata, S2000. If they are the same design then thats the type I want in my front.
Dennis
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.003s) Memory: 0.6127 MB (Peak: 0.7002 MB) Data Comp: Off Server Time: 2026-06-07 04:23:16 UTC
