reasking a question about hubs just to be sure #994068 04/17/10 04:56 AM
Red1979 Offline OP
Ok tuesday I am finishing my gear swap and I am going with lockouts on the front....Mine is a 87 ram 50 and the hubs are on a....I would say between an 83 and 86 just want to be sure b4 I buy them
1987 Dodge Ram 50
2.6 5 speed
2 inch body lift 31x11.50 Swamper LTBs
4.62 gears lsd rear and welded front with lockouts
Weber carb waiting to be installed
Re: reasking a question about hubs just to be sure [Re: Red1979] #994069 04/17/10 05:50 AM
The 4wd drive hubs are the same for the Monteros, at least, from 1983 to 1991. The Gen II Montero spindle may be different, but I wouldn't know that because I don't have any. However, the only difference in the Gen I Montero parts that mount to the hub are the brake disc for 4-cyl (early) and 4-cyl (late)/V6. You're probably not at risk mixing pickup parts around, but be aware of the disc diameter as the trucks received the larger rotors earlier.
Russell
Re: reasking a question about hubs just to be sure [Re: rxinhed] #994070 04/17/10 05:58 AM
PHIL_ Offline
I can confirm first hand that the hubs will fit up to at least 94 (and later): I put Aisin's on my genII. They fit. AFAIK Mitsu used the same hub from the beginning, until the genIII when they were no longer usable. So you should be good to go.
Re: reasking a question about hubs just to be sure [Re: PHIL_] #994071 04/17/10 06:15 AM
Same Aisin manual hubs fit my '87 as my '95. It's what they come off of that is the question, if you're not buying new ones.
Re: reasking a question about hubs just to be sure [Re: JohnnyBfromPeoria] #994072 04/17/10 10:19 AM
torquemonster Offline
yes...the Aisin Manual hubs will fit all GEN II trucks up to 2000.
Re: reasking a question about hubs just to be sure [Re: torquemonster] #994073 04/17/10 01:22 PM
Red1979 Offline OP
Ok thanks just wanted to be sure....by the way they are coming off of an eariler ram 50
1987 Dodge Ram 50
2.6 5 speed
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6130 MB (Peak: 0.6830 MB) Data Comp: Off Server Time: 2026-06-07 11:36:34 UTC
