22RE Oil Leak #994115 04/18/10 07:34 PM
daryl Offline OP
Being new here I figure this may be the place to get help.
Bought an '89 short bed Toy w/ 22re 4 cyl from my neighbor for a couple hundred bucks. Other than the standard issues that come with a truck with 180k plus on it, it has an oil leak somewhere on the right side. After a few pressure washes, I've been unable to locate the source. Oil is thrown around the engine compartment causing the belts to squeal and leave lovely dribble lines wherever it's parked. My initial guess would be a possible front crank seal but not sure. Any help would be greatly appreciated.
Re: 22RE Oil Leak [Re: daryl] #994116 04/20/10 04:02 PM
toyrunner Offline
I would pull the oil pump off and replace the crank seal and the oil pump seal at the same time. Good place to start.
Welcome to the "Wire" <img src="/forums/images/graemlins/kewl.gif" alt="" />
1985 SR5 4Runner
eLocked with Carter Lock
4.7:1 single case
Davez Offroad twin stick
Re: 22RE Oil Leak [Re: daryl] #994117 04/20/10 05:10 PM
engnbldr Offline
>>>*Here are several possible common source of hard to find oil leaks.
1. Top oil pump hold down bolt. That hole is threaded all the way through the cover and the threads must be sealed or it will leak without fail.
2. Oil pump seal at the front, or the O-ring at the rear.
3. Valve cover itself, oil drips down and is thrown back by air off the fan and appears to be coming from everywhere.
4. Porosity in the timing cover itself, low down on the right side.
One of those is the usual source of the leak.....*EB
*Beats the he** outa me!....*LOL**...
Re: 22RE Oil Leak [Re: daryl] #994118 04/22/10 01:32 AM
daryl Offline OP
Thanks for the starting points. This has been driving me nuts for awhile now.
Re: 22RE Oil Leak [Re: daryl] #994119 04/23/10 06:54 PM
Bigcat Offline
Along with what's already been said, if the timing chain is loose and slapping inside the cover, it may have rubbed a hole in the cover. Clean it off real good and run it you should be able to see it.
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6053 MB (Peak: 0.6707 MB) Data Comp: Off Server Time: 2026-06-20 20:23:23 UTC
