Page 3 of 3 1 2 3
Re: Random No Start, Gen 1 V6, all electrics replaced. [Re: fasteddy] #994147 04/20/10 04:21 AM
BoiseMontero Offline OP
There's not even a test method or removal method in the fsm. I think there's two photoelectic sensors in the dizzy housing. There's a coarse slotted wheel and a fine slotted wheel, one being the tdc sensor and the other the crank angle sensor. There's not a lot to go wrong with them, sinde the light source is an led and the sensor is a photocell, so I'd recheck the connector in the bottom of the dizzy for corrosion, and check the dizzy guts for dirt on the led/photocell.
The icm you put on is just an electronic switch, a power transistor, the black box on the coil bracket, that turns on and off the coil connection from coil- to ground to trigger the spark. Sounds like time for a junkyard distributor.
Thanks. I ordered a rebuilt ecu this morning so fingers crossed that will solve it.
1989 SWB V6 5 speed 230K
Re: Random No Start, Gen 1 V6, all electrics replaced. [Re: BoiseMontero] #994148 04/20/10 04:22 AM
Thanks, I've been here before, some of you might remember me, I moved and got a new computer and could not recover my user info, got no help from wire when I emailed.
Who or which address did you email? I don't recall seeing a message from you but I will say my memory's not perfect. Nice rig BTW.
Re: Random No Start, Gen 1 V6, all electrics replaced. [Re: off-roader] #994149 04/20/10 04:38 AM
Looking back I think my mistake was emailing the main wire page.
Message to editor@4x4wire.com sent on march 9th. Never got a response.
Re: Random No Start, Gen 1 V6, all electrics replaced. [Re: BoiseMontero] #994150 04/22/10 03:02 AM
Hey guys I was able to pull a code today, 23 tdc also common with crank angle sensor I guess, so new distributor will be here friday along with the ecu, and a new IAC so NOW all electrics have been replaced. Grand total spent this month $2645. Yikes
and btw my new to me DRB II, Mitsubishi adapter and 3.0 cartridge got shipped out today <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: Random No Start, Gen 1 V6, all electrics replaced. [Re: BoiseMontero] #994151 11/04/10 05:46 PM
Been a long time, I just got a pm about this so I better update with final findings;
Ordered distributor Hitest reman, it gave me a bucking problem, so I sent it back and got a Cardone 'new'. It solved all problems. So after all that it was the crank angle sensor and pulling a code would have given me the answer. Oh well, now every electrical part is new so there shouldn't be any more trouble..... until the next thing goes bad <img src="/forums/images/graemlins/shiner.gif" alt="" />
Page 3 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.098s Queries: 16 (0.006s) Memory: 0.6174 MB (Peak: 0.6995 MB) Data Comp: Off Server Time: 2026-10-24 08:15:18 UTC
