How's it connected? #994187 04/19/10 06:07 PM
The_Rusty_Gear Offline OP
88 4Runner V6
There is a wire leading from the positive terminal of the battery to the fuse box. It has broken and needs to be replaced. How is it connected at the fuse box? Do I need to remove and disassemble the fuse box? Pop off some plastic? I didn't poke around too much for fear of breaking something else!
What gauge is that wire (maybe upgrade to a thicker wire at the same time?
Thanks in advance!
1988 4Runner, V6 Auto, Mostly Stock
32 x 9.5 Swampers
Re: How's it connected? [Re: The_Rusty_Gear] #994188 04/20/10 01:31 AM
kewlynx Offline
Like most of the stuff in the fuse box, you unbolt it from the fender and roll the box over; should be a couple terminal lugs you see.
On bigger wire gauge, absolutely NOT. The wire is the size its supposed to be for carrying the load. Exceed it, and you might wind up frying stuff.
My plugged nickel on that one.
**ubi apis- ibi salus**
Re: How's it connected? [Re: The_Rusty_Gear] #994189 04/20/10 02:24 AM
Adam F Offline
Yes, unbolt the box and you'll see how it comes apart. I believe you snap it out of the fuse box, and then there's a 10mm bolt that holds the lug to the terminal.
I have to disagree on the wire size. You can ALWAYS go thicker, just not thinner. Thinner wire cant carry as much load, and will fry stuff if you try to push too much amperage. A larger wire will carry more load, and you can never have too thick of a wire. As long as you can fit it in the terminal on the fuse box.
97 4R, stock, daily driver
Re: How's it connected? [Re: kewlynx] #994190 04/20/10 11:40 AM
Ralph Offline
[/quote]
On bigger wire gauge, absolutely NOT. The wire is the size its supposed to be for carrying the load. Exceed it, and you might wind up frying stuff. [/quote]
Words mean something. The bigger the number the smaller the wire. A #22 wire is way smaller than a #4.
Use the biggest copper wire that will fit and you will be all right. Not the biggest number but the biggest wire.
Ralph
1991 Toyota 4x4 Standard Cab Pickup.
engnbldr cam and head.
Doug Thorley Headers
Home Made Cat Backs
30x9.5x15 BF Goodrich All-Terrain M/T KM2
Re: How's it connected? [Re: Ralph] #994191 04/22/10 04:57 AM
KiwiCowboy Offline
If memory serves me right, the wire from the battery to the fuse buss is 8 awg. I replaced mine with 6awg with no problem.
PHP: 7.4.33 Page Time: 0.012s Queries: 15 (0.009s) Memory: 0.6055 MB (Peak: 0.6706 MB) Data Comp: Off Server Time: 2026-07-16 21:24:37 UTC
