Dummy needs help disecting electrical connectors! #994192 04/19/10 06:11 PM
The_Rusty_Gear Offline OP
Specifically, the turn signal connectors. The wire has broken very close to the connector, so I'm hoping to put in some new wires and blades. I got most of the connector apart, but can't remove the blades from the plastic housing and can't see where they are catching.
Maybe it's easier to replace the connector? If so, where can these be found? I dont recall seeing these new connectors at Canadian Tire or the like.
Thanks!
1988 4Runner, V6 Auto, Mostly Stock
32 x 9.5 Swampers
Re: Dummy needs help disecting electrical connectors! [Re: The_Rusty_Gear] #994193 04/22/10 05:06 AM
KiwiCowboy Offline
The pins are usually removed by inserting a very small pick and depressing the tang that keeps the connector from being pushed out. Some tangs are on top and some are on the bottom. The first one will take you a while but don't give up. After you get one out, you can see the tang and the rest are easy.
Another option is to get the connector from a salvage yard and just cut the wires as far back as you can get. Then you can just splice the wires together with but connectors or solder them.
Re: Dummy needs help disecting electrical connectors! [Re: KiwiCowboy] #994194 04/22/10 05:23 AM
4Crawler Offline
Yes, usually if you study the connector closely, you can see which side of the terminal will press inwards. Also helps to push in the wired end fully to get the little tang clear then use a small tool (I like a jewelers screwdriver) to push in the tang then at the same time pull out the wired end:
Some other tricks I have used on my VW to repair tail light sockets:
- http://www.4crawler.com/Diesel/CheapTricks/index.shtml#SocketRepairs
Re: Dummy needs help disecting electrical connectors! [Re: The_Rusty_Gear] #994195 04/22/10 03:57 PM
Cholltero Offline
They make a tool specifically for taking these apart . Using a fine pick works for me though.
ie:
http://shop.willyselectronics.com/browse.cfm/ht-2023-pin-insertion-molex-/4,8872.html
85' 4x4 e-cab flatbed 22r carb ((SOLD))
86' 4runner, 22re , "60 buck truck"
95' 4runner, 22re,5sd, last of the good ones
02' Tacoma prerunner, 2.7L, 5spd., 4x4
Re: Dummy needs help disecting electrical connectors! [Re: Cholltero] #994196 04/22/10 04:07 PM
4Crawler Offline
ie:
Yes, have one of those tools and it works for the Molex connectors which have the round pins and hollow round mating parts. But each different type of connector will need a different tool and/or technique to release the pins.
Re: Dummy needs help disecting electrical connectors! [Re: Cholltero] #994197 04/24/10 06:10 PM
Davepet Offline
I have on occasion, pounded a piece of coat hanger wire flat enough to slip in the connector to release pins. A little grinding or filing is usually needed to shape the "tool" properly.
Dave
PHP: 7.4.33 Page Time: 0.011s Queries: 15 (0.007s) Memory: 0.6131 MB (Peak: 0.7001 MB) Data Comp: Off Server Time: 2026-11-16 08:54:57 UTC
