D.O.A. in the garage #994214 04/20/10 01:54 AM
N
Nodelk Offline OP
It has been awhile since I have posted! I have a major problem, that hopefully someone here has an answer. I drove it my T' all weekend with no problems, pulled it into the garage last night, all was well. I went to start it for work this morning, and all it did was crank over. Didn't even fire once. <img src="/forums/images/graemlins/angry.gif" alt="" /> <img src="/forums/images/graemlins/confused.gif" alt="" /> The timing belt was replaced 20k miles ago. The only thing I can think is the fuel pump crapped out. After cranking a couple of times, I didn't smell fuel in the exhaust pipe. I have disconnected the battery to see if resetting the computer will do something. ARRRG this sucks! <img src="/forums/images/graemlins/angry.gif" alt="" />
'95 T100 Xtra Cab 4x 3.4 Ltr, Custom brush guard, Raider Canopy, Warn Hubs
DELK it's whats for dinner when you don't fill your tags...No DEer, no eLK. I hate BBQ'ing my tags...they keep bursting into flames!
Re: D.O.A. in the garage [Re: Nodelk] #994215 04/20/10 02:10 AM
N
Nodelk Offline OP
I reconnected the battery (it had been disconnected for about 2 hours). Zip, zero, nada! <img src="/forums/images/graemlins/barf.gif" alt="" /> Still a no-go. <img src="/forums/images/graemlins/frown.gif" alt="" />
Re: D.O.A. in the garage [Re: Nodelk] #994216 04/20/10 02:22 AM
A
Alluvial_Plains Offline
Did you check the fuses (esp. the EFI fuse under the hood)?
Re: D.O.A. in the garage [Re: Alluvial_Plains] #994217 04/20/10 03:55 AM
N
Nodelk Offline OP
All is good in the fuse box (fusible link) and elsewhere. <img src="/forums/images/graemlins/frown.gif" alt="" /> This is the first "major" issue I have had in 150k miles (besides the idler arm 3x, draglink recall, radiator, normal wear & tear). Luckily this didn't happen on one of my hunting or camping trips into the hinterlands!
Re: D.O.A. in the garage [Re: Nodelk] #994218 04/20/10 06:47 AM
kewlynx Offline
There's a 1996 T100 FSM here if you want to download it; look for the fuel open circuit relay test I believe:
http://www.ncttora.com/fsm/index.html
**ubi apis- ibi salus**
Re: D.O.A. in the garage [Re: Nodelk] #994219 04/20/10 12:33 PM
BamZipPow Offline
You should be able to listen fer the fuel pump when you turn the ignition to the "On" position but do not try to start the engine.
The things you need to establish first is...does it have fuel, air, and spark?
Do you know if there are any codes stored? You can pull the codes without the engine running with an ODBII scanner. I use Scangauge II to monitor my engine status as well as being able to pull codes. <img src="/forums/images/graemlins/smile.gif" alt="" />
When was the last time the fuel filter was changed? <img src="/forums/images/graemlins/wink.gif" alt="" />
Re: D.O.A. in the garage [Re: Nodelk] #994220 04/20/10 01:13 PM
foxtrapper Offline
FWIW, every few months mine will lose pressure in the fuel system. Which means when I crank it to start, it does nothing but crank.
Band-aid fix is to crank the heck out of it. It builds pressure in the fuel system and finally fires up.
Might want to try cranking yours a good bit longer than usual and see if it gradually starts to chuff and fire and finally run.
'97 T-100 SR5
Re: D.O.A. in the garage [Re: foxtrapper] #994221 04/20/10 03:18 PM
BamZipPow Offline
I think that's yer fuel pressure regulator and the vacuum hose that's connected to it. Have you inspected that hose? <img src="/forums/images/graemlins/wink.gif" alt="" />
Re: D.O.A. in the garage [Re: BamZipPow] #994222 04/20/10 07:50 PM
foxtrapper Offline
Heavens! Why inspect and fix something when I can just crank the heck out of it once in a while and go driving?
Seriously, it could be the regulator, but it could also be a few other things. None of them have the decency to appear bad to a cursory visual inspection, and I'm not willing to throw parts at it just yet.
'97 T-100 SR5
Re: D.O.A. in the garage [Re: foxtrapper] #994223 04/20/10 11:56 PM
BamZipPow Offline
Well...the hose would only cost like a couple bucks if it needed replacing... <img src="/forums/images/graemlins/wink.gif" alt="" />
PHP: 7.4.33 Page Time: 0.011s Queries: 16 (0.008s) Memory: 0.6432 MB (Peak: 0.7682 MB) Data Comp: Off Server Time: 2026-07-16 03:26:05 UTC
