Cooling system flush, 6hr type #994401 04/21/10 12:53 AM
toyhooter Offline OP
After reading the "To rebuild or not to rebuild, that is the question... " post and seeing the images of the clogged water passages in the head, I decided a cooling system flush was in order. I used the Prestone 3 to 6 hour cleaner. I have seen cleaner pond water than the water that I drained out of that engine. Yikes! A completely worthwile thing to do to your 20 plus year old Monty.
ToyHooter
90 LWB Montero
Sliders, Dual Bouncies, K&N, Flowmaster, Rancho Stabalizer, KYB Gas Adjusts,
ARB Compressor Under Hood, ARB Locker Waiting Garage Floor, Spare Tire Bike/CB Ant Mount
"I didn't do it, you didn't see me, you can't prove it."
Bart Simpson
Re: Cooling system flush, 6hr type [Re: toyhooter] #994402 04/21/10 02:23 AM
leadheavy52 Offline
I gave the water jackets a good cleaning when I did my valve job, but I don't think I managed to get into the ports that well. I will heed your advice and tackle this weekend. Thanks.
-Austin
1988 SWB Montero - 2.6L - 5-speed
Weber Carb
(Coming Soon) Rugged Ridge AVM Hubs
Re: Cooling system flush, 6hr type [Re: toyhooter] #994403 04/27/10 04:52 AM
Thought I would add a follow up to this post. I took a road trip Saturday to see the folks. About 120 miles away. I saw that the Monty was running cooler. The temp needle sat at halfway or a slightly below that. The last time I was out that way in Febuary I noted that the temp needle was slightly above halfway when exiting the frwy. I had never seen the temp needle north of halfway. That started me thinking about the cooling system maint and possible upgrades.
ToyHooter
90 LWB Montero
Bart Simpson
Re: Cooling system flush, 6hr type [Re: toyhooter] #994404 04/28/10 01:54 AM
hazy_daze Offline
You'd be well served to do this type flush every 2 years, making sure to use distilled water in your antifreeze/coolant mixture. Good stuff <img src="/forums/images/graemlins/kewl.gif" alt="" />
PHP: 7.4.33 Page Time: 0.020s Queries: 15 (0.017s) Memory: 0.6014 MB (Peak: 0.6572 MB) Data Comp: Off Server Time: 2026-11-18 22:46:39 UTC
