87 22re engine replacing 85 22re in 4runner
#994429
04/21/10 02:48 AM
I got a 87 22re out of a 3/4 ton camper that had been transformed into a wrecker to replace my 85 22re that I locked up. I got the computer and most of the sensors and wiring out of the 87. It had a 5 speed and my 85 has an automatic. I was wondering if I could use most of the sensors and all from the 87 and if it would plug right up. Also does anybody know if I should use the computer from the 5 speed 87 or the 85. Does the transmission make any difference with the computer? I'm not much of a mechanic, my brother will be doing most of the work. Any thoughts would be greatly appreciated.:)
Re: 87 22re engine replacing 85 22re in 4runner
[Re: greenseaman]
#994430
04/21/10 06:08 AM
Safest bet would be to just use the 87 long block and bolt all the 85 goodies to it. I know there was an injector switchover somewhere along the way (a high vs. low impedance thing), but mechanically everything should be identical. You could try to mix and match parts if you wanted, but for the most likely to succeed scenario, just switch the core mechanical parts.
[Re: stock87]
#994431
04/21/10 10:37 PM
Thanks! I really appreciate the help!
[Re: greenseaman]
#994432
04/21/10 11:56 PM
I'm with stock87 on this one.
Bolt your intake and fuel rail (with injectors) from the '85 to the '87 , plug-n-play done!
[Re: Staceman]
#994433
04/22/10 01:39 AM
Make sure you remove the pilot bearing from the crank before you go bolting up that auto tranny. I made that mistake - once. Otherwise, I agree, use the longblock and be on your way.
Todd
1986 Pickup extracab longbed "Woody edition" SAS - 33's, 5.29's, lockright rear.
02 IS300 SportCross - my "DD" 94 2wd v6 extracab 04 Outback Wagon- wife's/family car
[Re: Elbow_Greese]
#994434
04/22/10 03:21 AM
Thanks for all the help guys! I greatly appreciate it!
[Re: greenseaman]
#994435
04/22/10 05:06 PM
Make sure you remove the pilot bearing from the crank before you go bolting up that auto tranny. I made that mistake - once. Dang! Nice save Todd! I'll be sure to keep this one in mind.
[Re: Staceman]
#994436
05/30/10 04:31 AM
Finally got the engine in today! Thanks for all the help guys! We used wads of wet paper and a 8mm socket to get the pilot bearing out. What a neat trick that I found on youtube... We did have to switch out the fuel injectors and used the 85 EFI stuff and wiring harness. It wasn't as bad as I thought it was going to be. Thanks for everything. I'm heading up to GSMTR in Sparta, TN in a little bit and we'll see how it holds up:)
[Re: greenseaman]
#994437
05/30/10 04:36 AM
Right on; good luck!! Too bad the donor camper is so far away; that axle under there is pretty awesome.
I use the newspaper trick on pilot bearings too. <img src="/forums/images/graemlins/kewl.gif" alt="" />
[Re: greenseaman]
#994438
05/31/10 04:18 AM
post up that U tube vid... I would like to see it. thanks
