Re: thread size for the oil pressure [Re: pcc] #994472 04/21/10 10:11 PM
shawnsdad Offline OP
yes I understand. taper. auto meter is not tapered!!!
many thanks
loren
92 montero rs 3.0 locked rear
Re: thread size for the oil pressure [Re: shawnsdad] #994473 04/21/10 10:37 PM
KrzyDav Offline
I used the 1/8 npt on mine with no problems.
NAPA list a fitting British to NPT,,,it's like $35 , a tap is much cheaper...
dave h.
Re: thread size for the oil pressure [Re: shawnsdad] #994474 04/22/10 12:33 AM
P
pcc Offline
Is this a misprint then?
http://www.autometer.com/cat_accessoriesdetail.aspx?vid=59
Re: thread size for the oil pressure [Re: pcc] #994475 04/22/10 12:39 AM
Va_Stumpy Offline
I used a similar adapter from my local parts store. It was brass & the male threads were longer than the threads on the old sending unit. Worked fine . Good luck.
Va_Stumpy
89 Raider
"Never judge horsepower by exhaust"
3.0
automatic
stock as a rock
Dual Bouncy Seats
Re: thread size for the oil pressure [Re: shawnsdad] #994476 04/22/10 02:28 AM
NathanC Offline
Mine came from AutoMeter and was tapered. Was it even the right thread per inch?
'06 Dakota QC 4.7 6sp 4x4
'88 Mighty Max
'77 KZ1000 fun old bike
Re: thread size for the oil pressure [Re: NathanC] #994477 04/22/10 09:53 PM
I bought two of the recomended 2269 and neather is tapered. got one from the place some on here showed in a post. and it is tapered
many thanks
loren
PHP: 7.4.33 Page Time: 0.006s Queries: 16 (0.004s) Memory: 0.6141 MB (Peak: 0.7000 MB) Data Comp: Off Server Time: 2026-06-20 19:08:24 UTC
