Back again for some needed advice #994482 04/21/10 06:11 PM
88raider4morgan Offline OP
My Mechanic is just about finished with my Daughter's '88 Raider restoration but we have one nagging problem. The OD relay is burnt out and can't signal the O/D to engage. I have read that one can ground the sensor if that is the problem but what do you do if it's the relay? Is there another source of power that can be substituted to power the O/D solenoid? Does anyone know of an aftermarket relay that can be substituted for the original? I canÆt locate a replacement part.
Re: Back again for some needed advice [Re: 88raider4morgan] #994483 04/21/10 09:16 PM
Are the V6 and 4-cyl OD relays the same? I have the former. Second, have you verified the temp sensor on the intake manifold is operating correctly? This is another common part to fail and leave the Monteros with no OD. BTW, not the temp sensor for the temp gauge. <img src="/forums/images/graemlins/smile.gif" alt="" /> <img src="/forums/images/graemlins/smile.gif" alt="" />
Re: Back again for some needed advice [Re: rxinhed] #994484 04/22/10 02:28 AM
Va_Stumpy Offline
The stock OD relay has the part # on it... It's a bear to get to. You can get the # off the FSM. I gave the # to the guy @ Auto Zone & had a replacement the next day.
Va_Stumpy
89 Raider
"Never judge horsepower by exhaust"
3.0
automatic
stock as a rock
Dual Bouncy Seats
Re: Back again for some needed advice [Re: 88raider4morgan] #994485 04/22/10 05:00 AM
if you"ll notice there were a couple of guys with multiple relays. give them a call
Re: Back again for some needed advice [Re: 88raider4morgan] #994486 04/22/10 03:23 PM
I was able to locate one last night.
Thanks again for the advice. Once I get the beast home I would like one of you more experienced owners to drive her and tell me if she is up to par.
Re: Back again for some needed advice [Re: 88raider4morgan] #994487 04/22/10 08:00 PM
Mike_Pirie Offline
Well, we are having that little Montero get together dowm in Ocala on May 15-16 if you want to meet some folks and try the truck out...
1992 montero, cranked t-bars, OME springs, 1-1/2" spring spacers, Homemade rear bumper and roof rack, 33" BFG AT, 1" body lift, Superwinch hubs, '95 SR locking rear axle, was AT - now V5MT1-3 5spd.
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6110 MB (Peak: 0.6810 MB) Data Comp: Off Server Time: 2026-06-07 05:29:47 UTC
