Gen II t bars into Gen I #994522 04/22/10 01:11 AM
radish150 Offline OP
I guess maybe I should already know this by now, but must I change my Gen I UCA?s to Gen II in order to use the Gen II torsion bars, or are they a simple bolt in?
Thanx
"We don?t need more health insurance, we need health ASSURANCE" Dr. Douglas Graham.
http://curezone.com/
90 Montero LWB 4D56 2.5 TDI, AT with OD, dual bouncy seats, H4 headlights, hellas, bull bar, 32" Wranglers and about to get some LEGS!
2001 Yamaha WR-426
Re: Gen II t bars into Gen I [Re: radish150] #994523 04/22/10 03:13 AM
Have you measured both in length? I'm having visions of past threads and them being different.
Re: Gen II t bars into Gen I [Re: MontyMcV] #994524 04/22/10 03:28 AM
justice Offline
The bars mount to the lower A Arms so the uppers wont matter. From whats been discussed here, the 94+ bars are too long, but sparkem has interchanged with 92/93 bars and said those ones will fit.
Re: Gen II t bars into Gen I [Re: justice] #994525 04/22/10 06:36 PM
Great Justice, thanx. My bars have "taken a set" (?) and even if you crank them to the max they dont get any harder. My shocks are doing all the work up front...
They heavy? Such a pain in the arse to buy used stuff here <img src="/forums/images/graemlins/rolleyes.gif" alt="" /> Anyone have any????
2001 Yamaha WR-426
Re: Gen II t bars into Gen I [Re: radish150] #994526 04/22/10 06:42 PM
justice Offline
Have you tried "re-indexing" the bars yet? That might give you what you need up front with out replacing the bars.
Re: Gen II t bars into Gen I [Re: justice] #994527 04/22/10 08:08 PM
0778drz110 Offline
x2
Re: Gen II t bars into Gen I [Re: justice] #994528 04/22/10 09:10 PM
When I last had my torsion bars out and missed the proper index mark by just one notch, the adjuster hung down so far I'm sure I would have hit it on something. Your bars would have to be pretty tired for it to work right, I think.
YMMV.
Re: Gen II t bars into Gen I [Re: JohnnyBfromPeoria] #994529 04/23/10 01:00 AM
sparkem Offline
The early gen2s will fit because of the engine and tranny combo is the same length. I dont know if the stock bars for the gen2 and gen1 are the rate or not. But the gen1 bars work just fine. I swapped mine out because my 93 had heavy duty swayaway bars from AUS.
Re: Gen II t bars into Gen I [Re: justice] #994530 04/23/10 01:50 AM
No Justice, have not, but rather than open my mouth and reveal my complete ignorance on the subject, I will take a look around on the net and see what I can find out.
Thanks
2001 Yamaha WR-426
Re: Gen II t bars into Gen I [Re: radish150] #994531 04/23/10 02:04 AM
justice Offline
re-indexing is when you remove the bars and rotate them one (or more) spline inboard and then re-install to give the adjusters more range of motion to twist the bars. This may get you some extra lift with worn bars, but wont give you any additional stiffness IMO.
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.004s) Memory: 0.6400 MB (Peak: 0.7635 MB) Data Comp: Off Server Time: 2026-06-20 18:48:13 UTC
