aahhh! ive had it with this 2.6! #994583 04/22/10 06:35 AM
brnt2180 Offline OP
4.3 here i come. one question though. has anyone thats done the 4.3 conversion mated up with a standerd tranny? if so, hows it goin now? i musta missed that post.
nother day,nother busted knuckle.
Re: aahhh! ive had it with this 2.6! [Re: brnt2180] #994584 04/22/10 11:25 PM
With the added torque of the 4.3, I'd find it hard to believe that it would be a long lasting conversion. You might be better off doing engine/tranny/transfer case swap. Then in reality you will only have to deal with fooling with the driveshaft. Anything else to do with the swap you are going to do any way (fuel, cooling, exhaust, etc) you might as wellcome in with running drivetrain. Fortunately running S-10/S-15 4WD are fairly easy to obtain for reasonably prices. Helps a lot with the swap. And I'd even switch to automatic, saves a lot of fabbing and makes the swap easier. It's an idea. Good Luck! <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: aahhh! ive had it with this 2.6! [Re: Mudraider] #994585 04/23/10 02:33 AM
0778drz110 Offline
4.3-way more power, probably better mpg too, an early 90s are the best
700r4-reliable, easy to replace/parts
np231-most desirable transfercase, look for an early 90s with a manual shifter
the 2.6 manual wont hold up with a 4.3 <img src="/forums/images/graemlins/shiner.gif" alt="" />
Re: aahhh! ive had it with this 2.6! [Re: 0778drz110] #994586 04/23/10 02:37 AM
justice Offline
The members here that did this swap used the entire drivetrain out of the donor, Landraider, Don and a couple others..
Re: aahhh! ive had it with this 2.6! [Re: 0778drz110] #994587 04/23/10 05:04 AM
LandRaider Offline
A 4.3 would destroy a KM148 in short order.
I suggest you buy a running wrecked S10, and swap the entire drivetrain over.
Youve got a long list of adaptations to make.
Exhaust system, Fuel system, shifters for trans, and transfer case, throttle linkage, driveshafts, motor mounts, trans mount, efi wiring, dash/tach interfacing, starting system, charging system, power steering system, AC if youre going to use it, cooling system, trans cooler.... etc....
Lots of stuff to tackle.
Re: aahhh! ive had it with this 2.6! [Re: LandRaider] #994588 04/24/10 08:11 AM
brnt2180 Offline OP
found a running tpi 4.3,std out of a blazer. <img src="/forums/images/graemlins/smile.gif" alt="" /> i`ll start it in a week or so. i`m not worried, ive got good material to fall back on & two mechanics who have 74 yrs of this kinda stuff between them. besides, this will help me study for my ase tests right? wish me luck. <img src="/forums/images/graemlins/patriot.gif" alt="" /> i do plan on swapping the entire drive train,as well as doing the suspension upgrades ive read. there`s alot of junkyards out here and no humidity.ive found six and three-quarter montero/raiders 1st and 2nd gens.
Re: aahhh! ive had it with this 2.6! [Re: brnt2180] #994589 04/25/10 07:42 AM
brnt2180 Offline OP
by the way, im asking if anyone thats done the swap has used the std tranny out the donor vechile and if they`ve run into any long term problems with any installation fab? <img src="/forums/images/graemlins/confused.gif" alt="" />
Re: aahhh! ive had it with this 2.6! [Re: brnt2180] #994590 04/25/10 08:27 AM
Six and 3/4 Montero/Raiders huh? <img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" /> I dunno why but that just had me laughing.....................
Re: aahhh! ive had it with this 2.6! [Re: brnt2180] #994591 04/26/10 12:58 AM
0778drz110 Offline
it will explode, the standard breaks with a 4cyl why would a large V6 work??
Re: aahhh! ive had it with this 2.6! [Re: 0778drz110] #994592 04/26/10 01:07 AM
He has an a/t. The km148 is supposed to handle 300ftlbs of torque. I think the 4.3 has a lot less than that, like 225ish ftlbs.
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.005s) Memory: 0.6393 MB (Peak: 0.7645 MB) Data Comp: Off Server Time: 2026-06-07 03:49:57 UTC
