Spinning Sound around my Shifter #995251 04/28/10 05:12 AM
4
4runTAZ Offline OP
When i put my 4Runner in neutral i can hear a spinning sound and the shifter seems a little loose. Any help before i stater breakin it down?
Re: Spinning Sound around my Shifter [Re: 4runTAZ] #995252 05/10/10 07:12 AM
jigger Offline
Most likely the input shaft main bearing. Could also be the needles inside the input shaft.
Does it go away if you push in the clutch?
Re: Spinning Sound around my Shifter [Re: jigger] #995253 05/15/10 04:55 AM
xrtim Offline
Could be the ring that holds the gear shifter into the tranny. Is the shifter loose?
PHP: 7.4.33 Page Time: 0.015s Queries: 15 (0.010s) Memory: 0.5923 MB (Peak: 0.6453 MB) Data Comp: Off Server Time: 2026-11-03 17:14:58 UTC
